Newbie day 3.
I have a Martin Jerry wall switch RP-ZB-S01.
I can control the lights from Hubitat or from the physical buttons on the switch. My problem is that when I press the physical button, no message is registered in Hubitat, in Logs or Events.
I'm guessing I need a better driver, but I really don't know much of anything. The driver it installed on its own was "Generic Zigbee Multi-Endpoint Switch". I also tried "Generic Zigbee Switch" which wasn't any better.
I don't see any clues from the product to suggest it's a multi-endpoint switch; it looks just like a typical switch to me. I see you've tried "Generic Zigbee Switch," which sounds more appropriate, but I don't see that you for sure ran "Configure" after switching, so I'd suggest that if you haven't (or change the driver and then reset and re-pair the device, without removing it from the hub first -- probably overkill, but could help in the odd event it's not getting the configuration).
I tried switching to "Generic Zigbee Switch", and with no different results, I switched back to the "Multi-Endpoint". Somewhere along the way, things started working as expected. I did so many things, I have no idea what fixed it.
Hey Ken, did you try this driver? I have a switch using this driver and it works excellent. I noticed with a greenlite LED bulb, that this switch never fully turns off the bulb, but I can only tell at night.
Zemismart ZigBee Wall Switch Multi-Gang - Device Driver for Hubitat Elevation hub
I don't remember if I did anything different when I added mine. But it has always worked just fine. I use the event of Physical to trigger some other lights when it is manually switched. They both have the Generic Zigbee driver.
One thing I noticed about these switches, it doesn't make any difference whether you hit the up paddle or the down paddle. It changes state either way, ie off to on or on to off.
Mine are both in no neutral locations which is why I bought them.
