I am currently using Ecobee Integration 1.0.2 to connect to my thermostat. I am then using Maker Api to expose that for use in Node Red. From the look of it, the Ecobee device is setup in Maker Api, but there are no subscriptions to any of the ecobee events. I believe this what is causing my Ecobee device data to not equal what the Maker Api is sending to Node Red. For example, the ecobee device shows a temp of 72 degree. but when calling the get device info REST call, it returns an older temperature of 71 degrees.
Am I missing something? I've tried searching for info, but have not found anything related to the interaction between these two apps/devices.
Additional Info:
Running 2.2.4.156 on a C-7
