Hello,
New user here and this could be a newbie issue.
I've setup Hubitat and integrated the App for Lutron RadioRA2. We have a large RadioRA2 setup at our house and I added a few devices manually to Hubitat. I can control dimmers and switches just fine so I know we are communicating with the Main Repeater just fine.
I added a keypad, device 54 to the system and I wanted the Away scene to run from that keypad - which is button 6. If I go into the device interface and "press" button 6, what shows up in the logs is this:
[dev:14] 2019-10-22 14:54:28.128 [info] button 6 pushed
[dev:6] 2019-10-22 14:54:28.063 [info]rcvd: DEVICE,54,6,3
[dev:14]2019-10-22 14:54:27.927 [info]Garage Entrance Keypad button 6 was pushed
But nothing happens in my system.
If I run the Lutron Connect app, and press the Away button from the app, everything works fine. The first "event" that shows up in the Hubitat logs is:
[dev:6]2019-10-22 15:03:53.426 [info]rcvd: DEVICE,54,6,4
Notice that the difference on what is happening on device 54 is in the first instance (Hubitat), it is sending a press command (3) using the Lutron integration protocol. In the second case, the command that is sent is a release - command 4 in the protocol. It appears that the button release is what is driving the event, not the press.
I'm wondering what I'm doing wrong in terms of trying to get this scene to fire by simulating a button press on a keypad. Is there a different way I should be doing this?
Thanks,
Arn
