There is a trick for this. Pair it to a phantom switch and make Hubitat use the device as the trigger. By phantom switch, I mean a device that is added, paired to the occ sensor, and then physically removed. The switch (which is no longer powered or even in your house) will still have it's state communicated over telnet. Expensive, but if you know somebody who also has Radio Ra 2 switches, it works. There does seem to be a delay though - if you have Hubitat use the Lutron sensor (which is actually the phantom switch) to turn on a real Lutron switch, it can take 3-4 seconds for the action to happen. Seems like the it's an issue with telnet - something is causing a delay.
