Getting a low memor warning on my C8, memory is at 446012 according to Hub Info driver:
Haven't seen this type of warning before, and it seems odd given my hub's memory level. I've refreshed the Hub Info driver device page, and reloaded the HE browser window. No change.
@support_team@gopher.ny Holding off on rebooting in case this is interesting and you want to look at engineering logs. Hub seems to be working fine.
I switched a couple Motion and Mode lighting rules over to Room Lighting and I'm now getting low memory warning (hub monitor) cycles every couple hours.
I don't know if it actually is the switch from Motion to Room that's caused it.
What is the frequency you are collecting the memory stat. I changed mine down to every min because i wasn't seeing momentary drops. After doing so i van see occasions of significant drops. Those numbers though don't make sense.
I thought that warning was suppose to trigger below 100mb.
Does the warning go away if memory returns to normal levels? I e. Could there have been a temporary drop but then return to the level you are seeing now?
Do you have any charts with the history of the memory readings, to see if there was any drop in the recent past?
I haven't been tracking memory (never had any significant memory issues) so I don't have any history to look at.
One thing, however - memory hasn't changed since I noticed the alert ealier this evening...still at exactly 446012 that was reported three hours ago. If the memory reported stays there for a lot longer wondering if that may be indicating that memory reporting is "stuck."
Something is up...below is from the freeMemory endpoint. So memory is very low (83,676). It appears that Hub Info is not getting the correct value. I'm going to reboot the hub now.
Oh man, DOH (all caps!) - I had uninstalled and re-installed the driver a while back when I was troubleshooting some other stuff, and forgot to set up my poll queues. Just re-assigned it to a queue and memory is polling normally.
Operator error...sorry for the confusion.
I do have one question - should the manual Refresh on the Hub Info Device page work even if free memory isn't assigned to a queue?
