No sense in doing that when... ![]()
So, if you're affect, the most you can do is probably go to the beta. That process is explained here:
You can also manually add the device by sending the DSK to an HTTP endpoint on the hub or, more easily, using a popular community app that does the same for you, but if you can make the app work, that's a lot easier to start with.
That being said, I'm not sure I'd recommend using Z-Wave devices outside the regions where they are authorized (unlike Zigbee, it is different worldwide due to differing regulations -- and their preference for lower frequencies).
