Lock code wont send notifications
for some reason when I use the Parent code, I do not get a notification, I also want HSM to turn off (Have not added that yet) but its not triggering.. am I doing something wrong, this should be super simple..
Edit: if I run actions, I get the notification to happen.
There's a bug with more than one lock being part of a trigger. If you set each lock up with it's own rule, it will probably work.
[quote="[BUG] [2.3.2.141] Multiple Locks as Trigger for RM 5.1, post:1, topic:98078"]
M 5.1 rule that I've been using for quite a while that recently stopped working. Unfortunately, I'm not exactly sure which version it stopped in, but I think it was around the time I upgraded to 2.3.2.134. The original rule was written f
[/quote]
That seemed to have worked for the Mudroom.. Ok, I will just make a copy for the 3 doors .. hope it gets fixed soon
