Hi, maybe I missed it in this thread but how I can delete LCM and get it to remove all of the stored values in it? i.e. Right now I don't have two of the locks any more. They died and I'm replacing them. I went into LCM and tried removing the codes for those locks but the removal was stuck in a "pending" state. Then I decided I was going to delete LCM and start over. I went to delete the app and then add it back but that just pulled in all the previous values.
I'd like to delete it, clear all the previous values and just start over. What am I doing incorrectly?
LCM doesn't store any lock codes, it just reads codes from any existing lock driver events..
If a lock is no longer functional, you would need to delete it from Hubitat to remove any codes.
So I have 3 yale locks and 1 schlage...when I moved to Hubitat - I had problems with them until I installed repeaters since then everything has been fine...except the battery life on one Yale lock. I had to replace batteries 4 times and the othe locks are still aboe 95%. therefore, I decided to exclude/add back that lock - I read that this can 'reset' the device and stop it from 'searching' killing battery life...Once i did this, my problems started....I could no longer use the lock manager to manage the other locks - updates failed...did all kinds of things...so I finally excluded all the locks, factory reset them...and I still cannot add them back...nothing. I followed the post by SmartHomePrimer and still nothing. I have tried over, and over...rebooted the hub, tried again...they worked fine for a year...now nothing. Any ideas?
And which model Schlage? I don’t have the Yale, So won’t be able to help on that; do have BE469NX and BE469ZP Schlage. Sounds like your issue isn’t a Lock Code Manager issue (the subject of this thread), but a device pairing issue with C-5 and firmware 2.2.3.135.
2.2.3.135 seems to have inclusion issues with Z-Wave (my new C-7 is staying powered but unused, no devices until things stabilize). I’d suggest going back to an earlier firmware that worked for you, do the inclusion, then, if you want, restore a later firmware that you have been using successfully.
My Schlage is a BE469NX and my Yales are YRD446. Since I have 3 yales - I have spend most of my time work on those...only did a brief attemp ton the Schlage but will try again..
Wait for the FW release that is expected this week, it may help w/your issues, and will generally provide a lot of Z-Wave cleanup.
I've paired the same Schlage lock, took the hub to within three feet of the lock and it paired immediately. This was with an older version of the FW, 135 is a hot mess for me and many others.
So I'd suggest you take a breather and try again w/the next FW release.
