Did you choose that driver manually? If so, hit "Configure" on the device page to run that command and see if it helps (you won't visibly see anything happen). Maybe try it anyway even if it paired this way, or try re-pairing (reset the device itself, but don't remove it from Hubitat, then just rediscover it) if nothing else.
