Deselect those combo devices in the app on Hubitat "Amazon Echo Skill", then wait a little bit and if they don't go away on the Alexa side, you may need to also delete them from Alexa.
Not sure how new devices would have gotten added to your ghost away lighting? Deleting devices and re-adding them is supposed to fix it.
For the away mode lighting. Alexa called this "Away Lighting". So you could try a few voice prompts. Alexa, ----
- is away lighting enabled
- disable away lighting
- I'm home (this is supposed to turn off the away mode)
- Is hunches enabled
- Disable hunches
In theory but how do they know that skill is not triggering the light by itself? Is it not their code.
Go to Alexa App > More > Settings > Hunches
Does anything show in the activity history?
Then check More > Alexa Privacy > Review Smart Home device History
I checked in mine and it may not actually show you what triggered the device to change. I do not command my devices that often so its hard to find an example. Maybe something will stand out?
