I'm new to Hubitat but not home automation. I'm moving my system from Homeseer.
I included 4 wall switches and they will all turn on the lights when the switch is manually pushed and if I activate them through the web interface or iPhone app. Two of the switches do not show a change in my dashboard when activated manually.
This causes an issue with a rule I created (similar to the one in Homeseer). I want to turn on a fan and another light when I manually turn on the main light. The rule works if activated through the webpage or iPhone but not when I manually press the switch. That switch is one of the ones that does not register the change in the webpage of phone.
How many total z-wave/zigbee devices? How many of these are z-wave/zigbee repeaters? ^ Z-Wave devices all within 20 feet of the hub
Are the switches on Hubitat's list of compatible devices? Brand, model number? Listed under generic but I changed to GE Enlighton and no change
Assuming z-wave, are they z-wave plus? Most older z-wave devices do not support "instant status". Should be z-wave Plus but may not be. I'll have to check on that
Do the switches have the latest firmware from the manufacturer? Not sure. Never needed that before with Homeseer.
I have a feeling it is the Z-Wave Plus issue as the two switches in question are kinda old. Great information!! I hope it is the issue.
If you look at the Hubitat Device page for the device, at the clusters (near the bottom of the page), if you see 0x5E that indicates a Z-Wave Plus device.
I have a houseful of new GE/Jasco wall switches and experience something similar. I was told by @JasonJoel that it was likely because the toggle switch is acting as a button switch and it takes time for the system to make sure you have double tapped or held the thing.
On the other hand, I've associated the switches using @JasonJoel 's driver and I get the same 3 second delay. I believe association is just on and off, and it's just communication between devices, so I don't know, maybe it's related to the switch.
@JasonJoel , check this out.
Having a lot of time on my hands I messed around with changing parameters. Most of them can't be changed except for 3 (led), and I think 4 (button direction), and.....19, which does I don't know what. But...changing 19 to 1 makes the action instantaneous!
Parameter 19. I have no idea what it does. I know it fixes this issue though.
You have to use a tool like the Basic Z-Wave tool to change Parameter 19 from 0 to 1.
Basic Z-Wave Tool (do a search) is a user device that allows you to change parameter values.
