Both are there. The transitionTime variable changes with setting the preferences, and the colortransitionTime doesn't change. Unfortunately the reported state is not reflected in the bulb, which appears to stay at the default 0.0 time.
It doesn't use the default transition time for SetLevel in any driver because it's using the one from the SetLevel command. But it's definitely using it for SetColorTemperature on the LIFX Color driver for me, but not, as you say, for the Day and Dusk driver.
Wait, I see what's happening. transitionTime is actually referring to the on/off time, not the duration it takes to change from level-to-level or color-to-color.
Nope, that's not it - there's a stray reference to colorTransitionTime in the Day to Dusk driver after the commented out block - if you change that to state.transitionTime. I probably missed it because of that commented code.
Let me know if that fixes it for you and I'll update the code in github tomorrow
I am watching this thread with interest and am massively impressed with how fast @rob has refined this set of apps / drivers.
Currently I'm using the latest version in conjunction with some scene setting wall switches for bedside lights - where this works really well. For the rest of the house I'm still using the HTTP driver so that groups turn on and off in sync.
@rob Is that something that may be solve-able on the roadmap at some point?
As far as I know we don't have any explicit multithreading capability in Hubitat, but it may be possible to build the protocol message packets just once and then fire them one at a time from a group device to the various devices in the group. It should at least be fairly quick, if not as good as multihreaded.
I probably won't start on that until I've got the Multizone and Tile support working though.
But that Python library has given me some ideas, thanks.
Just feeding back an issue I encountered last night and offering advise to stop anyone else getting the same issue.
So last night I had to reboot home Wi-fi (mesh network on Linksys Velop) as Wi-fi was playing up. Didnât think anything off it - usually no issues with a reboot and everything works well after.
I didnât notice any issues until I went into 2 bedrooms with Lifx bulbs (I have 9 in total around the house).
When going into the rooms the lights didnât come on which was strange.
I went into the Lifx app and tried switching lights on and off. No problems there. I then went into HE devices and tried switching the lights on. No response from the bulbs. Having a hunch, I went and did a device discovery of new devices. The 2 bulbs were discovered as new. The ânewâ bulbs responded to on button but the old one still didnât.
Bit of head scratching, I then looked at the device ID and was able to see the IP address was different between new and old. I went into the Lifx app to try finding the IP addresses of the bulbs but just couldnât see the info anywhere.
I then tried changing device ID to the working IP on the bulbs not working (purely to save having to edit all the rules to point to the right new bulb). Saving the settings didnât keep the new IP.
In the end, I went into every rule and changed the rules to point to the new bulbs and deleted the old bulbs. Everything working again.
Moral of the story - set your IPs for the Lifx bulbs to static. Lol and to help identify which bulb is which on your router, change your device device name at the same time which might help with future diagnosing of issues.
Fortunately for me I assumed IP reservations were needed as soon as I noticed the IP addresses were in the DNI. My Lifx bulbs were probably the only wifi smart devices I had that didn't already have them. Any integration that talks to devices locally (without a separate hub in between) I now assume needs reservations.
@kilowatts, you may want to edit your OP with this as a recommendation. Same for you github documentation @rob.
I started giving my bulbs static IPs a couple years ago, back when even the official app couldn't keep track of them. Since then I've given nearly everything connected to my router a static IP, for good measure.
I updated this app and now I am unable to set colors through my rules. Color temp works, changing brightness works, it just no longer sets the colors (blue, red, green, etc).
Yeah. I'm still paying around with it but I think it's actually a bug in rule machine. I got it to set color by adding a brightness value. With no brightness value, the rule now does nothing. This was changed in the most recent hubitat firmware.
Ah. I don't use colors for my LIFX bulbs in HE, just white temperatures, but I'll see if I can duplicate it. Which bulbs do you have? And is it a simple change from one color to another with no change in brightness?
Currently, on lines 809-816 in the Hubitat editor (in Github viewer it's 807-814) there's the following piece of code:
private static Map<String, Number> getScaledColorMap(Map colorMap) {
hue : scaleUp100(colorMap.hue) as Integer,
saturation: scaleUp100(colorMap.saturation) as Integer,
brightness: scaleUp100(colorMap.level ?: colorMap.brightness) as Integer,
kelvin : colorMap.kelvin
This code errors out when there's no brightness value set in the rules engine when just changing color, like this:
Log error:
[dev:139](http://192.168.3.150/logs#dev139)2019-03-04 08:57:03.607 am [error](http://192.168.3.150/device/edit/139)java.lang.NullPointerException: Cannot get property 'commands' on null object on line 98 (setColor)
[app:44](http://192.168.3.150/logs#app44)2019-03-04 08:57:03.574 am [error](http://192.168.3.150/installedapp/configure/44)java.lang.NullPointerException: Cannot invoke method multiply() on null object on line 849 (deviceSetColor)
If you replace that piece of code with the following code, everything works, with and without brightness levels.
if (colorMap.level != null) {
} else {
Admittedly, my modified code is probably sloppy, so use at your own risk.
Lost control of all my lights today. I tried going into the Master App and discovering new devices, but nothing happened when I clicked those buttons. I attempted to remove the Discovery device and try again, but that didn't work. So I ended up having to uninstall and reinstall the master app, which I believe means I need to remove all the bulbs and start from scratch. Sorry I don't have any logs to help with diagnosis other than a whole buncha java.lang.IllegalArgumentException: null on line 122 (poll), long after the fact.. Not sure what happened... I do have all my lights set with static IPs.
