Just discovered the update. Just tried setting with all of the bulbs together not in a group, no error messages but it doesn't seem to raise or lower. The on, off, and color changes are definitely so much faster than a few months ago!!
app:4182019-11-03 07:02:05.066 am infoAction: Start raising: Lifx Kitchen Bulb Sink, Lifx Kitchen Bulb Den, Lifx Kitchen Bulb Wine, Lifx Kitchen Bulb Fridge, Lifx Kitchen Bulb Pantry, Lifx Kitchen Bulb Banquette, Lifx Kitchen Bulb Basement
app:4182019-11-03 07:02:05.000 am infoPico Side Entry Rule: Kitchen Pico Side Entry pushed 2
dev:22019-11-03 07:02:04.846 am infoKitchen Pico Side Entry button 2 was pushed
dev:12019-11-03 07:02:04.790 am inforcvd: DEVICE,2,5,4
dev:12019-11-03 07:02:04.577 am inforcvd: DEVICE,2,5,3
app:4182019-11-03 07:02:02.796 am infoAction: Start raising: Lifx Kitchen Bulb Sink, Lifx Kitchen Bulb Den, Lifx Kitchen Bulb Wine, Lifx Kitchen Bulb Fridge, Lifx Kitchen Bulb Pantry, Lifx Kitchen Bulb Banquette, Lifx Kitchen Bulb Basement
app:4182019-11-03 07:02:02.746 am infoPico Side Entry Rule: Kitchen Pico Side Entry pushed 2
dev:22019-11-03 07:02:02.594 am infoKitchen Pico Side Entry button 2 was pushed
dev:12019-11-03 07:02:02.549 am inforcvd: DEVICE,2,5,4
dev:12019-11-03 07:02:02.249 am inforcvd: DEVICE,2,5,3
dev:9932019-11-03 07:02:01.918 am infoKitchenOverhead level was set to 50%
dev:9932019-11-03 07:02:01.911 am infoKitchenOverhead switch was turned on
dev:9932019-11-03 07:02:00.654 am infoKitchenOverhead colorName is Incandescent
dev:9932019-11-03 07:02:00.651 am infoKitchenOverhead colorTemperature was set to 2500
dev:9932019-11-03 07:02:00.619 am infoKitchenOverhead switch was turned on
app:4172019-11-03 07:02:00.571 am errorjava.lang.NumberFormatException: For input string: "0.0" on line 150 (indicatorHandler)
dev:9232019-11-03 07:01:59.143 am warnError occured with UDP message: SocketTimeoutException: Receive timed out
app:4182019-11-03 07:01:59.066 am infoAction: Color Temperature: KitchenOverhead: 2500: 50
app:4182019-11-03 07:01:59.027 am infoPico Side Entry Rule: Kitchen Pico Side Entry pushed 1
dev:22019-11-03 07:01:58.881 am infoKitchen Pico Side Entry button 1 was pushed
dev:12019-11-03 07:01:58.827 am inforcvd: DEVICE,2,2,4
dev:12019-11-03 07:01:58.585 am inforcvd: DEVICE,2,2,3
dev:9742019-11-03 07:01:56.148 am warnError occured with UDP message: SocketTimeoutException: Receive timed out
dev:9932019-11-03 07:01:55.219 am infoKitchenOverhead level was set to 0%
dev:9932019-11-03 07:01:55.211 am infoKitchenOverhead switch was off
app:4182019-11-03 07:01:53.638 am infoAction: Dim: KitchenOverhead: 0
app:4182019-11-03 07:01:53.596 am infoPico Side Entry Rule: Kitchen Pico Side Entry pushed 5
dev:22019-11-03 07:01:53.443 am infoKitchen Pico Side Entry button 5 was pushed
dev:12019-11-03 07:01:53.389 am inforcvd: DEVICE,2,4,4
dev:12019-11-03 07:01:53.162 am inforcvd: DEVICE,2,4,3
dev:9752019-11-03 07:01:41.262 am warnError occured with UDP message: SocketTimeoutException: Receive timed out
app:2272019-11-03 07:01:40.746 am debugSending DEVICE Event (Pantry Door | CONTACT: closed) to Homebridge at (172.16.16.14:8005)
dev:1672019-11-03 07:01:40.655 am infoPantry Door was closed
dev:9732019-11-03 07:01:38.166 am warnError occured with UDP message: SocketTimeoutException: Receive timed out
app:4182019-11-03 07:01:33.074 am infoAction: Start lowering: Lifx Kitchen Bulb Sink, Lifx Kitchen Bulb Den, Lifx Kitchen Bulb Wine, Lifx Kitchen Bulb Fridge, Lifx Kitchen Bulb Pantry, Lifx Kitchen Bulb Banquette, Lifx Kitchen Bulb Basement
app:4182019-11-03 07:01:33.021 am infoPico Side Entry Rule: Kitchen Pico Side Entry pushed 4
dev:22019-11-03 07:01:32.875 am infoKitchen Pico Side Entry button 4 was pushed
dev:12019-11-03 07:01:32.805 am inforcvd: DEVICE,2,6,4
dev:12019-11-03 07:01:32.233 am inforcvd: DEVICE,2,6,3
dev:9702019-11-03 07:01:32.157 am warnError occured with UDP message: SocketTimeoutException: Receive timed out
app:4182019-11-03 07:01:31.634 am infoAction: Start lowering: Lifx Kitchen Bulb Sink, Lifx Kitchen Bulb Den, Lifx Kitchen Bulb Wine, Lifx Kitchen Bulb Fridge, Lifx Kitchen Bulb Pantry, Lifx Kitchen Bulb Banquette, Lifx Kitchen Bulb Basement
app:4182019-11-03 07:01:31.578 am infoPico Side Entry Rule: Kitchen Pico Side Entry pushed 4
dev:22019-11-03 07:01:31.392 am infoKitchen Pico Side Entry button 4 was pushed
dev:12019-11-03 07:01:31.338 am inforcvd: DEVICE,2,6,4
dev:12019-11-03 07:01:30.966 am inforcvd: DEVICE,2,6,3
app:4182019-11-03 07:01:30.027 am infoAction: Start lowering: Lifx Kitchen Bulb Sink, Lifx Kitchen Bulb Den, Lifx Kitchen Bulb Wine, Lifx Kitchen Bulb Fridge, Lifx Kitchen Bulb Pantry, Lifx Kitchen Bulb Banquette, Lifx Kitchen Bulb Basement
app:4182019-11-03 07:01:29.969 am infoPico Side Entry Rule: Kitchen Pico Side Entry pushed 4
dev:22019-11-03 07:01:29.778 am infoKitchen Pico Side Entry button 4 was pushed
dev:12019-11-03 07:01:29.722 am inforcvd: DEVICE,2,6,4
dev:12019-11-03 07:01:29.317 am inforcvd: DEVICE,2,6,3
app:4182019-11-03 07:01:28.254 am infoAction: Start lowering: Lifx Kitchen Bulb Sink, Lifx Kitchen Bulb Den, Lifx Kitchen Bulb Wine, Lifx Kitchen Bulb Fridge, Lifx Kitchen Bulb Pantry, Lifx Kitchen Bulb Banquette, Lifx Kitchen Bulb Basement
app:4182019-11-03 07:01:28.200 am infoPico Side Entry Rule: Kitchen Pico Side Entry pushed 4
dev:22019-11-03 07:01:28.031 am infoKitchen Pico Side Entry button 4 was pushed
dev:12019-11-03 07:01:27.888 am inforcvd: DEVICE,2,6,4
dev:12019-11-03 07:01:27.624 am inforcvd: DEVICE,2,6,3
Updated Rule:
