I would like to be able to use Multi Zone Templated of my LIFX LED Strips in Scenes.
For example, I want to set up a scene, that switches on the LED Strip and uses a theme similar to the "exciting" Color Template from the LIFX App
I thought this would be straightforward as they are now recognized as LIFX Multizone Devices, and that I would be able to capture the current State of the LIFX Strip.
But when I try to capture it, it captures only one of the colors¯_(ツ)_/¯
I haven't been able to find the way to capture all the colors of the Strip, Is there something obvious I am missing here?
AFAIK this isn't supported with Scenes - I'm assuming you're using the LIFX Local Control App/Drivers?
If so, you can certainly capture the multizone state with the driver, and likewise re-apply it. Rule Machine can call the custom command to re-apply the multizone state... This could probably trigger off of the activation switch for the scene turning on?
I've packed my one multizone device away until I can mount it on the wall, but I seem to remember that there's a Zones Save button which expects a name, and a corresponding Zones Load button. I'm not sure if the use of child zones has any impact on this.
Once you've saved the zones you should be able to use a custom action in Rule Machine to load the named zones.
