But they don't actually support HE. Someone intercepted the API calls from the mobile app to create the "awesomeness" of the Life360 connector.
FYI... If you delete the Life360 connector before HE does a fix for the login, you end up with orphaned push notifications showing up as warnings in the log. They will be a web IP that can no longer connect to the app Id for the now deleted Life360 Connector. Hopefully they just expire on Life360 and eventually stop.
