Hi Guys,
Just wondering if any has bought this and got the RGBW working?
Hi Guys,
I have a couple. Don’t work too well directly attached to Hubitat, so I joined them to my Hue hub. They work just fine. They’re not as bright as Hue strips, but perfectly good for accent lighting.
Take a look here...
M
Thanks. yes, I saw that post, but it's kinda working -ish as mark.cockcroft said.
You can't set the color from within HE though, right?
I set the colour within the Hue App, then capture that as a Scene in HE, works great.
Puedes explicar como capturas la escena con HE??
No creo que sea posible obtener color de las tiras de luz Lidl si están conectadas a HE. Vinculo el mío a mi Hue Hub y establezco el color allí, luego creo una escena dentro de HE \ Apps y uso la función de captura dentro de la configuración de escena
Lo haces con la app Groups and Scenes? Yo no logro capturarlas correctamente. Cuando activo la escena siempre se enciende como haya estado encendido el led la ultima vez....
Gracias por contestar
