Leviton ZW4SF locks up
I have a strange one that I haven't seen others with the same problem.
I have 3 leviton ZW4SF fan speed controllers on 3 different ceiling fans (AC).
I have a rule that when my A/C cool runs, I set the speeds to each fan and turn them on, and when my A/C cool turns off, I turn the fans off.
I have tried the system driver (only 3 speeds though) and the user driver (ernie's driver with 4 speeds).
Initially, I thought it was because I was turning all the fans on at the same time in my rule, so I separated them and put in a 1 second delay between each fan command, thinking that the flood of commands was locking up the fan speed controller's processor.
What happens is randomly, one/two/all of the controllers with lock up and not turn on. Even pushing the "up" paddle at the switch does nothing.
The green power light is on, but does not change and the fan does not run.
I have to use the air isolation switch (power down, power back up) to reset the controller and then it will function.... for a while, but will eventually lock up again.
Does anyone have a clue as to what is going on or have any ideas as to what to try?
I like the 4 speeds, but NO speeds kinda defeats the purpose!
I have 2 of the Leviton controllers under ST using a slightly modified driver from the stock one. The only delay between commands I left in was between the Set and the subsequent Get when setting on/off or speed. Experimentation with my custom driver showed that if you requested the state immediately after setting it, you didn't always get the new value. And I'm guessing that's why the drivers all add delay between commands. I have 1000ms delay between set-get operations and that has always worked fine. (ST stock driver had 5000ms between in some cases.) However during experimentation with the driver and now in "production" I have never been able to lock the devices up or required to airgap reset them for any reason, including after power outages. They're even paired with S2 enabled.
Both of mine are running the firmware 1.08, which is what they shipped with.
HHmmm... thanks for the info.
My controllers are running FW version 1.8 not 1.08.
When they work, they work, so I will keep trying things but these are the only devices that I am having problems with and I have both Zwave and Zigbee devices, about 40 zwave and 30 zigbee (VERY rough estimate).
If the problem was repeatable, it would be easier to track down, but it is random and seldom.
We had thunderstorms today and a power dip, and none of my devices had problems, so they all survived.
I'm betting we're running the same firmware version, just a different reported version number (decimal reported as 8, perhaps one of our drivers is misinterpretting what this means 08 vs 8).
Here is what I see on the device page:
Under DATA, there is no FW version reported. Could be the driver I am using (user's Ernie)
What driver are you using? Your reported DATA is different than what I see.
I have these devices on SmartThings, using a driver I modified from the stock fan driver - I shortened the delays between commands that I felt were way too long. I likely added a few other attributes too, like MSR and firmwareVersion that the stock drivers never add.
Looking at Ernie's driver:
createEvent(name: "firmwareVersion", value: ${cmd.firmware0Version}.${cmd.firmware0SubVersion}", displayed: false)
I believe this is incorrect. cmd.firmware0SubVersion should be 0 padded to 2 digits. So 8 should not be treated as 8, it should be converted as a 2 digit 0 padded string.
So your 1.8 is the same as my 1.08. :slight_smile:
AHHA!! Thanks for clearing that up!
So, yes, ours are the same firmware.
Well I just found one of my controllers had locked up.
All the speed leds were full bright and there was no response from either paddle or the up/down switch.
I had to airgap to reset.
I just wish there were more options for a 4 speed controller available.
I might even consider a 3 speed but I like the flexibility of 4 speeds more, but this aint' cuttin' it!
I know this is an old post that I started and haven't gotten back to for a while...
BUT..
they still have ALL locked up at random times, and a power cycle does "unlock" them, but they are really annoying me for their cost, and they ALL lock up, even without power dips, where all my other devices do NOT lock up, so it appears to be these devices.
I am going to remove them from my mesh so no ghosts linger, and leave them powered up.
I will then run them and see if they still lock up (probably will though).
Then I will see how good the noise suppression is on the power supply in the control.
I believe that line noise is getting into the processor in the control and glitching, which locks up the processor.
I will also look at the supply with a scope and see how noisy it is, and see if I can add suppression to the power rails and see if THAT keeps them running.
The clue that they are locked up is that when I tap the paddle to run the fan, nothing happens and no indicators change, so even local control doesn't work.
I don't think that the zwave or the hub, is causing the problem, but bad design....
we'll see....
I just found this thread because my switch locked up. Sounds like a quality issue /defect with this product.
Well I have had all 3 of mine powered up but NOT paired with my hub, and they have NOT locked up and work fine with only local control.
Seems like the hub is sending crap data to them and they get confused and lock up.
I will re-include one of them and see how that goes.
I know this is a VERY old thread, but I wanted to update it.
I just re-included one of my fan speed controllers with S2 enabled (selected enable security when including and input the 5 digit code), so we'll see how this one works now.
The only clue that security is being used is the entry in the data table:
whatever S2:131 means?
Using Ernie's driver...
Update: I have 4 of these installed and 3 have locked up. It's really irritating, because I've got equipment on those circuits that I'd rather not power cycle.
What are you controlling these with? Just curious as to use cases...
This seems to be a widespread problem with these.
I have noticed this on several different forums, not only Hubitat but HA and others and reddit and Amazon... so it is evidently a design problem.
I am going to look into this further as I have a suspicion as to what is causing it...
I noticed that it only seems to happen when the control is paired, but when stand alone it seems to survive without locking up.
Of course, that is NOT why we have these controls, so it may be a Z-wave controller problem in the speed controller.
I do like that they are 4 speed and not the typical 3 speed, so I am going to try and see what I can find....
Just Hampton Bay fans. I don't even know how long they were locked up, because I hadn't used the fans all winter, but found 2 locked up when I tried to run the fans for the first time, after we had our first warm days. It's pretty egregious! You'd think they'd have some type of watchdog mechanism to reboot.
Means it can use S0 (128), S2 UnAuth (1) and S2 Auth (2)
So it is probably paired with S2 if you used SmartStart or inputted the DSK?
Can you tell the security type for sure by looking at Settings > Z-Wave Details.
When I paired the control, I used the DSK, and it is S2 so it is using security.
We'll see if the thing doesn't lock up now...
Thanks for the explanation!
I am trying S2 security to see if maybe the data that was being received by the control was corrupting the Z-wave receiver...
Not holding my breath but I will keep this thread updated.
Probably give it a couple of weeks since the lockups are very random.
