Hello! I am looking for some guidance with the Leviton dimmer issue. While testing the generic driver versus the Leviton Driver.....one of my dimmers is currently "stuck" at only brightening to 10%. This happens when I turn it on within Hubitat or at the dimmer itself. Any guidance on how to correct this?
Check and make sure that the device has firmware version 1.2. The previous firmware versions had some bugs.
If it's doing it with the physical switch you have a parameter setting issue. You either have "Maximum Light Level" or "Preset Light Level" set to 10%.
You can change it on the dimmer itself
or with the basic Z-Wave tool
