Leviton 800 Series ZW6HD Dimmer Driver
Using the Leviton Z-Wave Plus Dimmer Driver, here is the current state after operating the switch at the paddle:
Note: The driver's Brightness Correction is not enabled. Leviton documentation does say max 99.
As for State Variables, one and two should be "0", five should be "99". The universal scanner driver does pull the correct values in the options settings, but no driver seems to update the State Variables section.
