Im looking for some good and inexpensive RGBW light strips to put in my house that will connect to Hubitat. Needs to plug into 120 volt in the US.
That's a relative term... what price range are you looking for?
If you didn't do so already, be sure to check these strips that are popular among Hubitat Elevation users:
The cheaper ones I have found are these on amazon
GIDERWEL RGBWW LED Light Strip16.4ft,Dimmable 5050 RGB Cool White Warm White(2300K-6000K)450LEDs Multi-Color 12V 6 Wire RGB+CCT Ambiance Lightstrip Plus,Non-Waterproof,Only RGBCCT LED Strips https://a.co/d/bVtrAm6
Giderwel has a few different packages that appear to be fairly reasonable. Honestly the zigbee controller is what makes up most of the cost.
The controllers alone generally run $25-28 US unless you get them from somewhere like aliexpress.
