What's nice about leak sensors with Hubitat in general is you can get a notification, via Pushover or Text, exactly which sensor alarmed. So you can sprinkle the house with as many as you want and not get overwhelmed. Our existing hard-wired smoke detectors are hard to figure out and require a lot of walking around and looking up for a time after a false alarm. Also, my leak sensors have never false alarmed (knock on wood)-there's always water there.
Yes, I just got mine today. No pull tab, they were already activated. I only paired one of them, but it has a newer firmware version than my older ones and the battery reports 200%, as detailed in this thread: Battery reporting 200% (Linkind devices)
Update: Configure + Refresh, while pressing the button, shows the correct battery value. I've paired 2 of my 4 and they both show 100%.
All 4 of mine are paired and report 100% battery. I'd love to hear if anyone else got some with dead batteries.
New orders of the Linkind sensors still have some odd battery issues. On the 4 pack that I just bought:
I see the disclaimer in @coreystup's driver that:
How do I turn on battery/voltage reporting on the devices?
Did you use the Generic Zigbee Moisture Sensor (not the "no temp" one) as described here:
It auto-selected the (no temp) driver the first time I attempted pairing all 4. Just now I removed one and re-added it and it auto-selected the custom driver discussed above. It is reporting battery and voltage now, but I'll need to wait 16 hours to see if the battery reports again.
OK, something seems to have unjammed by removing and repairing because the "configure" button actually does something now whereas before...nothing. Guess I'll try repairing the other 3 and see what happens.
Got leak detector, from here,
https://pl.aliexpress.com/item/1005004870472389.html
it's detecting water (tested it), but is detected as scene switch
Manufacturer: _TZ3000_kyb656no
Endpoint 01 application: 41
Endpoint 01 endpointId: 01
Endpoint 01 idAsInt: 1
Endpoint 01 inClusters: 0001,0003,0500,0000
Endpoint 01 initialized: true
Endpoint 01 manufacturer: _TZ3000_kyb656no
Endpoint 01 model: TS0207
Endpoint 01 outClusters: 0019,000A
Endpoint 01 profileId: 0104
Endpoint 01 stage: 4
inserted into water
dev:752023-05-05 16:45:51.969debugLAZIENKA D WYCIEK did not parse descMap: [:]
dev:752023-05-05 16:45:51.966debugLAZIENKA D WYCIEK raw: descMap: [:]
dev:752023-05-05 16:45:51.964debugLAZIENKA D WYCIEK description is zone status 0x0001 -- extended status 0x00 - sourceEndpoint:01, zoneId:06, delay:0000
removed from water:
dev:752023-05-05 16:48:21.268debugLAZIENKA D WYCIEK did not parse descMap: [:]
dev:752023-05-05 16:48:21.266debugLAZIENKA D WYCIEK raw: descMap: [:]
dev:752023-05-05 16:48:21.263debugLAZIENKA D WYCIEK description is zone status 0x0000 -- extended status 0x00 - sourceEndpoint:01, zoneId:06, delay:0000
Search for Neo Coolcam Zigbee Water Leak sensor
Thank you, it is working on that driver. Why I'm not supprised, that this is again your driver? ![]()
FWIW, that's the exact same one I wrote about here Request adding fingerprints for iAlarm/Meian devices
I have it working with as the Generic Zigbee Moisture Sensor built-in type.
Indeed, I overlooked that. Anyway it works fine, confirming that.
FYI - kind of a bummer, I kind of liked these cheap sensors, but it appears the Linkind has discontinued them:
Most of my water and contact sensors are Linkind, they are reliable and inexpensive.
Their website no longer shows any sensor products, although their contact sensors as of May 18, 2023 remain available on Amazon.
And they took AA batteries. I have 16 of them and really like them--bummer they appear to have been discontinued.
I just bought (and tested) those: https://pl.aliexpress.com/item/1005004870472389.html
It not got destroyed after contact with water. It detected water immediately, and reported what there is no longer water, too. So far working, not dropping from mesh. I can't speak about battery consumption, because I have it plugged into mesh only by a bit more than one week.
Yep saw those and considered, but I ended up going with the ThirdReality ones because I put a lot of value in the AAA batteries vs the coins and the larger size doesn't matter for my application.
I see.
In my case size matters, and I hate to use AAA batteries, because they could leak electrolyte, and destroy devices, but in your case, if you already have tons of AAA batteries, the situation is different.
The link goes to door sensors. I canβt find the Linkind water detectors anywhere. Have they stopped selling them?
Unfortunately and Afaik, they are no longer available.
