I'm using the in-box Keen Vent driver.
After replacing batteries that died, I turned on debug and clicked Configure to make sure everything was working as expected.
When I did, I noticed I got a lot of CatchAll messages in the log. Is this normal (I wouldn't think so, but I'm not a zigbee guy).
Also, there is no event for battery, for instance, after hitting configure. Maybe that is as expected, too, but I would have thought the switch, battery, and level events in the log would have made device events...
dev:1542019-03-27 05:04:46.627 pm infoXavier Bedroom Smart Vent battery is at 100%
dev:1542019-03-27 05:04:46.620 pm debugparseReportAttributeMessage: read attr - raw: 25260100010A21002064, dni: 2526, endpoint: 01, cluster: 0001, size: 0A, attrId: 0021, encoding: 20, command: 01, value: 64
dev:1542019-03-27 05:04:46.617 pm debugparse: read attr - raw: 25260100010A21002064, dni: 2526, endpoint: 01, cluster: 0001, size: 0A, attrId: 0021, encoding: 20, command: 01, value: 64
dev:1542019-03-27 05:04:43.175 pm infoXavier Bedroom Smart Vent is 100%
dev:1542019-03-27 05:04:43.173 pm debugparseReportAttributeMessage: read attr - raw: 25260100080A000020FE, dni: 2526, endpoint: 01, cluster: 0008, size: 0A, attrId: 0000, encoding: 20, command: 01, value: FE
dev:1542019-03-27 05:04:43.171 pm debugparse: read attr - raw: 25260100080A000020FE, dni: 2526, endpoint: 01, cluster: 0008, size: 0A, attrId: 0000, encoding: 20, command: 01, value: FE
dev:1542019-03-27 05:04:42.167 pm infoXavier Bedroom Smart Vent is on
dev:1542019-03-27 05:04:42.162 pm debugparseReportAttributeMessage: read attr - raw: 25260100060A00001001, dni: 2526, endpoint: 01, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 01
dev:1542019-03-27 05:04:42.159 pm debugparse: read attr - raw: 25260100060A00001001, dni: 2526, endpoint: 01, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 01
dev:1542019-03-27 05:04:41.563 pm infoXavier Bedroom Smart Vent is 100%
dev:1542019-03-27 05:04:41.562 pm debugparseReportAttributeMessage: read attr - raw: 25260100080A000020FE, dni: 2526, endpoint: 01, cluster: 0008, size: 0A, attrId: 0000, encoding: 20, command: 01, value: FE
dev:1542019-03-27 05:04:41.559 pm debugparse: read attr - raw: 25260100080A000020FE, dni: 2526, endpoint: 01, cluster: 0008, size: 0A, attrId: 0000, encoding: 20, command: 01, value: FE
dev:1542019-03-27 05:04:40.539 pm infoXavier Bedroom Smart Vent is on
dev:1542019-03-27 05:04:40.535 pm debugparseReportAttributeMessage: read attr - raw: 25260100060A00001001, dni: 2526, endpoint: 01, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 01
dev:1542019-03-27 05:04:40.532 pm debugparse: read attr - raw: 25260100060A00001001, dni: 2526, endpoint: 01, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 01
dev:1542019-03-27 05:04:33.664 pm debugparseCatchAllMessage: catchall: 0104 0403 01 01 0040 00 2526 00 01 115B 07 01 00
dev:1542019-03-27 05:04:33.662 pm debugparse: catchall: 0104 0403 01 01 0040 00 2526 00 01 115B 07 01 00
dev:1542019-03-27 05:04:32.040 pm debugparseCatchAllMessage: catchall: 0104 0403 01 01 0040 00 2526 00 01 115B 07 01 00
dev:1542019-03-27 05:04:32.036 pm debugparse: catchall: 0104 0403 01 01 0040 00 2526 00 01 115B 07 01 00
dev:1542019-03-27 05:04:30.616 pm debugparseCatchAllMessage: catchall: 0104 0402 01 01 0040 00 2526 00 00 0000 07 01 00
dev:1542019-03-27 05:04:30.614 pm debugparse: catchall: 0104 0402 01 01 0040 00 2526 00 00 0000 07 01 00
dev:1542019-03-27 05:04:30.451 pm debugparseCatchAllMessage: catchall: 0104 0403 01 01 0040 00 2526 00 01 115B 07 01 00
dev:1542019-03-27 05:04:30.426 pm debugparse: catchall: 0104 0403 01 01 0040 00 2526 00 01 115B 07 01 00
dev:1542019-03-27 05:04:28.995 pm debugparseCatchAllMessage: catchall: 0104 0402 01 01 0040 00 2526 00 00 0000 07 01 00
dev:1542019-03-27 05:04:28.994 pm debugparse: catchall: 0104 0402 01 01 0040 00 2526 00 00 0000 07 01 00
dev:1542019-03-27 05:04:28.568 pm debugparseCatchAllMessage: catchall: 0000 8021 00 00 0040 00 2526 00 00 0000 00 00 0B00
dev:1542019-03-27 05:04:28.566 pm debugparse: catchall: 0000 8021 00 00 0040 00 2526 00 00 0000 00 00 0B00
dev:1542019-03-27 05:04:27.563 pm debugparseCatchAllMessage: catchall: 0000 8021 00 00 0040 00 2526 00 00 0000 00 00 0A00
dev:1542019-03-27 05:04:27.561 pm debugparse: catchall: 0000 8021 00 00 0040 00 2526 00 00 0000 00 00 0A00
dev:1542019-03-27 05:04:27.382 pm debugparseCatchAllMessage: catchall: 0104 0402 01 01 0040 00 2526 00 00 0000 07 01 00
dev:1542019-03-27 05:04:27.380 pm debugparse: catchall: 0104 0402 01 01 0040 00 2526 00 00 0000 07 01 00
dev:1542019-03-27 05:04:26.949 pm debugparseCatchAllMessage: catchall: 0000 8021 00 00 0040 00 2526 00 00 0000 00 00 0B00
dev:1542019-03-27 05:04:26.947 pm debugparse: catchall: 0000 8021 00 00 0040 00 2526 00 00 0000 00 00 0B00
dev:1542019-03-27 05:04:26.541 pm debugparseCatchAllMessage: catchall: 0000 8021 00 00 0040 00 2526 00 00 0000 00 00 0900
dev:1542019-03-27 05:04:26.540 pm debugparse: catchall: 0000 8021 00 00 0040 00 2526 00 00 0000 00 00 0900
dev:1542019-03-27 05:04:25.936 pm debugparseCatchAllMessage: catchall: 0000 8021 00 00 0040 00 2526 00 00 0000 00 00 0A00
dev:1542019-03-27 05:04:25.935 pm debugparse: catchall: 0000 8021 00 00 0040 00 2526 00 00 0000 00 00 0A00
dev:1542019-03-27 05:04:25.542 pm debugparseCatchAllMessage: catchall: 0000 8021 00 00 0040 00 2526 00 00 0000 00 00 0800
dev:1542019-03-27 05:04:25.541 pm debugparse: catchall: 0000 8021 00 00 0040 00 2526 00 00 0000 00 00 0800
dev:1542019-03-27 05:04:25.354 pm debugparseCatchAllMessage: catchall: 0000 8021 00 00 0040 00 2526 00 00 0000 00 00 0B00
dev:1542019-03-27 05:04:25.351 pm debugparse: catchall: 0000 8021 00 00 0040 00 2526 00 00 0000 00 00 0B00
dev:1542019-03-27 05:04:24.927 pm debugparseCatchAllMessage: catchall: 0000 8021 00 00 0040 00 2526 00 00 0000 00 00 0900
dev:1542019-03-27 05:04:24.926 pm debugparse: catchall: 0000 8021 00 00 0040 00 2526 00 00 0000 00 00 0900
dev:1542019-03-27 05:04:24.343 pm debugparseCatchAllMessage: catchall: 0000 8021 00 00 0040 00 2526 00 00 0000 00 00 0A00
dev:1542019-03-27 05:04:24.341 pm debugparse: catchall: 0000 8021 00 00 0040 00 2526 00 00 0000 00 00 0A00
dev:1542019-03-27 05:04:23.918 pm debugparseCatchAllMessage: catchall: 0000 8021 00 00 0040 00 2526 00 00 0000 00 00 0800
dev:1542019-03-27 05:04:23.916 pm debugparse: catchall: 0000 8021 00 00 0040 00 2526 00 00 0000 00 00 0800
dev:1542019-03-27 05:04:23.322 pm debugparseCatchAllMessage: catchall: 0000 8021 00 00 0040 00 2526 00 00 0000 00 00 0900
dev:1542019-03-27 05:04:23.320 pm debugparse: catchall: 0000 8021 00 00 0040 00 2526 00 00 0000 00 00 0900
dev:1542019-03-27 05:04:22.305 pm debugparseCatchAllMessage: catchall: 0000 8021 00 00 0040 00 2526 00 00 0000 00 00 0800
dev:1542019-03-27 05:04:22.304 pm debugparse: catchall: 0000 8021 00 00 0040 00 2526 00 00 0000 00 00 0800
dev:1542019-03-27 05:04:20.258 pm debugparseCatchAllMessage: catchall: 0000 8021 00 00 0040 00 2526 00 00 0000 00 00 0700
dev:1542019-03-27 05:04:20.257 pm debugparse: catchall: 0000 8021 00 00 0040 00 2526 00 00 0000 00 00 0700
