Personally I wouldn't use the 36 buttons for the Magic Cube, I have enough trouble with just doing the basic 7! I set them up in Button Controller and it was very easy. I'm not at home but as I recall, I only needed one Button Controller instance to handle all the buttons.
What I did just to play but ended up being very helpful, was to start out just having announcements done when I would do the various movements, like "Cube shaken", "Cube slid" etc. Then once you are sure all that is working OK, wire up to what you really want to happen.
I pretty much did the same thing. I also labeled the cube with pips like you find on dice. Those have now been replaced with pictures of various combinations of light and dark bulbs for the bedroom.
As for the complexity of 36 buttons, there's a lot of duplication. Flip to face-6, tap face-6, shake face-6 all do the same thing. Three buttons one function so six functions ads up fast.
Hello again, sorry to bother you, could you post a copy of the cube driver you are using on HE, the last update broke functionality and I reverted the hub back to 2.0.4 but I don't have a copy of the old working driver. Thanks.
