You could just use a dumb hot water heater timer device. Those have been around for decades and are reliable. Not as cool as a true smart home device, but probably more reliable and cheaper.
umm thats an option - in the winter it moves from 6-8am and 6-8pm each day.
I also want to set other times as well - they are new water heaters so they probably only need to kick on 2-3 times a day.
kick on at 2-3 of till 7 kick on 705 and off at 10pm kick on again at 10am? something like that.
Looks really nice. Too bad it cannot handle my hot water heater's power requirements. My water heater needs something that can handle 5.7kW, or ~24A @ 240VAC.
That is a nicely packaged solution! And I really like Zigbee, so this is the best solution I have seen that meets my requirements. Thank you for sharing!
I'm a bid sad it is not usable for 4-wire applications, so can't be used for a range (neutral required for 120V components), even though it could handle the load.
right, but he used it on a well pump - having a well myself it is the only reason i can think to use product like this - it also much cheaper than a water shut off valve.
Gotcha, sure that makes sense for his use case. But since your original question was about controlling a hot water heater, just wanted to make sure you knew it could be used for that application as well. Sorry for any confusion.
