Is this the best option to control water heaters?
You are correct in that I used it for a well water shutoff in the event of a leak. I considered using a shut off valve, but you'd still need to shut the pump off to avoid dead heading the pump and damaging it.
Yep. I use mine on my water pump, effectively shutting off the water in the event of a leak.
so the water turn off every time you mop and make the sensor go off?
lol - i know that will happen to me
Fortunately, I have my sensors placed strategically out of usual water splash locations :smile:
Unfortunately GE/Jasco have discontinued this switch and it’s no longer available.
