I have a webCoRE piston that checks every 2 hours to see if a device has dropped offline and gone from Active to Inactive.
This gives me quick visibility that a motion sensor, for example, has become unresponsive.
Does anyone know of a way of doing this using RM for example or any other app.
Here is the piston for reference.
I suspect you know this app already since yours post is directly above it...but just in case ![]()
How on earth did I miss this!
I had a good search and rummage but I was obviously putting in the wrong keywords.
Thanks for the reply it looks like this is what I'm after.
I'm afraid this does not check the device 'Status' for Active or Inactive which is what I am after.
It checks for when the device last reported events. If the DH doesn't log it, then it will report even though it is still active.
I use this App all of the time. It has accurately reported devices that have stopped reporting in. For me, it works very well. You do have to pick a decent time-frame based on how frequently the device is used, to avoid false alarms.
