Yeah, there is an issue with ZW on a Pro migration -- the ZW Details page is blank and although ZW devices appear to come over OK, they are all unresponsive.
In my limited testing before reverting back to my C8, zigbee and other stuff seemed really great!
Nice! I thought I recalled you mentioning your migration went smoothly as well! Glad to here that Z-Wave is working correctly, at least for a C8 to C8 Pro migration!
Appears then to an intermittent failure. We've had another user reporting failed Z-Wave restore on the C8-Pro, both of his hubs (C5 and C8-Pro) were on 2.3.7.145. And Hydro w/both on beta.
so, on my current C8 is on beta AND has Protect on it, have not yet received my PRO yet (its not on beta obviously, and not on hub protect either ). Do I need to get the C8Pro on beta before I start a migration and do i need to get it on protect also? is there something I am missing or misunderstanding
Hub Protect is not normally required to migrate to a newer hub.
It appears that having both hubs on the beta worked for @JasonJoel. I'm not sure if both his hubs were also on Hub Protect, he'll have to comment. Migration failed first time for @hydro311 w/both his hubs on the beta.
At one point there were comments that having both hubs on Hub Protect could make it work.
Agree that waiting is likely the best approach at this point. Fix coming soon. (And yes, I realize that's a triggering phrase. )
yes .. hub protect not on both and not very common to be on both if you are replacing as most will the c8.. then you transfer the hub protect.. so not reallly a solution...
Ha, yep, I was just trying a do-over on my migration and now zero cloud backups are available. So perhaps they are making headway on the backend for the solution - fingers crossed!
