I want to chime in because like the original poster, I was at wits end trying to get a coherent system for a client up and running. I have a decent amount of experience with HomeKit, Caséta, and Smartthings. (I also have a lot of technical experience with wireless control systems including RA2, BT/BLE, WiFi, and proprietary wireless control systems in a factory setting.) But, I wanted local control, local access for security reasons and after a lot of research and testing in a "lab" setting, I landed on Hubitat. My adventures lasted about 3 months until I ended up with a system that is reliable... with a few caveats. And there was a point in time where I was so disgusted with Hubitat that I was about to move to Home Assistant or something else.
First, house size and construction have an insane impact on the reliability of your system. In two test situations (one was my office - about 400 sq ft - and the other was a 4k sq ft home) I had no issues adding and controlling devices. BUT, I was only adding and controlling about 12 devices. In my real-world, client home situation, I have over 120 devices (which is theoretically do-able off one hub), but the house is 7k sq ft. and even though there aren't construction materials that create natural RF, one hub and extenders simply didn't work.
Second, the original system I built had the hub literally in the center of the home and 5 Aeotec Range Extender 7s installed in locations where we were able to determine that we might have signal propagation and penetration issues. This worked until we reached ~60 devices. After that, it was a complete s-show.
Third, we only used Leviton, Aeotec, and originally Schlage door locks. I have always been happy with Aeotec and still am. I'm not sure if our choice of Leviton was a good idea or bad, but we have all of the switches, dimmers, and fan controls finally working (in a setup that I'll describe in a few more sentences). Schlage is a joke when it comes to Z-Wave. I had no clue what acrobatics Samsung/SmartThings had to do to get those locks working in other installations, but I won't be using their Z-Wave products again. It is too bad because they are physically well built and very secure from a lock picking standpoint (based upon reviews). We moved this new installation to Yale and Kwikset and have been very happy.
Fourth, we went scorched earth, divided the home into three zones and used one hub as a master with no actual devices connected to it. Why? Well, the reality is that regardless of what anyone says or what any company states, wireless is a nightmare and black magic. The potential for RF interference and problems is limitless. Once you get beyond 500 sq ft, it is almost impossible to determine where interference is coming from without very good tools (which we don't have for Z-Wave and don't know if exist).
Each working hub has two Aeotec Range Extender 7s and manage a maximum of 60 devices. One hub is solely dedicated to door locks because those devices happen to be located in one geographic location in the house (simply the way the house is built). The three "linked" hubs that have Z-wave devices attached then share those devices to the "master" hub and that hub does all of the automation.
Currently, the only devices that are not Aeotec, Yale, Kwikset, or Leviton are a few Fibaro motion sensors that we are testing (and are not yet happy with).
Lessons learned:
- location in respect to a hub matters
- distance matters regardless of range extenders
- STOP the moment you start seeing ghost devices. I don't know how it happens, but that is one problem we spent DAYS trying to figure out. I swear that we only started seeing ghost devices after adding about 45 to any hub, but we were working over the course of days and with two guys, so I am not sure if it was user error or an actual issue.
- interference comes from the least likely places. E.G. we had a hub 10 ft away from duct work, appliances, metal objects and it was hit or miss with changing switch states. We moved it to a location another 10 ft away that was non-symmetric with the location of most of the devices it is controlling and problems went away. Sometimes symmetry doesn't matter at all (which I know from building long-range wireless links, but I didn't think it would be the case over such short distances, relatively speaking).
- The Z-Wave device manufacturer matters. Aeotec has almost always been bullet proof for me (minus issues I have with battery drain on some of the multi sensor 6 devices we use). I can't speak to 99% of what Hubitat is compatible with, but I can say that I'll never use Schlage Z-wave devices again.
- The theoretical maximums of devices seems to have a distance/geographic range and I have no clue what that metric is or how you'd plan.
Should we need 4 hubs in a large house? I don't know. I never came across any examples or postings where that was the case. But, our system finally works reliably. When we build the next system for a house, we are going to allow no more than 1500 sq ft per hub. That is until we determine that it is possible and reliable to build out systems differently. We literally spent weeks troubleshooting switches that would work and then not work. For $150 retail (sometimes $125), it is not worth the time for us to buy fewer hubs.
I know this was a very long post, but your frustration mirrors what ours/mine was. The whole ghost device issue w/ C7 hubs is bs, in my opinion. But, I have a feeling that it is the devil in Z-wave and really outside of Hubitat's control. It was the most frustrating thing I've ever dealt with. I'd suggest evaluating the size of the space you are trying to manage and starting over. We would have saved weeks of work and phone calls had we done so ourselves...
To answer the question of your post directly: I think Hubitat is the best of a very hard to manage and messy product platform. I think Z-Wave and the spec around Z-Wave is ... problematic. Lots of versions, lots of manufacturers, and it will always be very difficult to test so many devices in a minimum number of environments that would make guidance reliable. Home Assistant is probably the next best option, but I can't imagine relying on it with no real commercial support. Hubitat is far from polished, but I still think they are the best choice for Z-Wave and Zigbee local control. (A lot of it has to do with the fact that it is a commercially available device, has a certain level of commercial support, and tries to help where it can.) I am just left with a very sour taste in my mouth, too, having struggled with ghost devices for so long and - after rebuilding and making sure none got attached to the new setup - realizing how detrimental they are to a working system.
