Irony is ....
When you finally get a UPS in order to prevent damage to the Hubitat database in case of an unclean shutdown, and you carefully shutdown the hub, but in the process of moving cabling the hub gets power, then looses it.... causing (for the first time in years) a corrupt database.
I really do appreciate the clean and easy procedure for doing a soft restart and particularly the option to reload a previous backup -- many thanks to the HE team for that.
