I bought this:
20 for $72 shipped ($3.60 per sensor). They also have a 40 pack option, but it worked out to $3.75 per sensor.
I bought this:
You may be disappointed with the v1 sensors. They do not route through repeaters, so all have to be within range of the hub.
@SmartHomePrimer Ah ■■■■. Wish I had known that. Is it just joining? Or will they never route though a repater?
Yeah... I read that after the purchase had already shipped.
I don’t have any, but from @dan.t ‘s post, it would seem they do not route. End device to controller only.
The only time I've ever had any issue (about 5 months now) with them dropping off is when I had the hub shutdown for extended periods of time, otherwise they have been super reliable and frequently update temp readings.
How far can you get from the hub?
My farthest one is approximately 40 feet and 3 walls in between.
These are the Iris 3320-L v2 Contact sensors... I have a few around the house and they work great. No issues so far. I bought some magnets on ebay as well, and use 3M COmmand Strips to mount both parts.
The V1 contact sensors can go through a repeater once they are joined to the hub. It is the joining procedure that can’t go through a repeater.
I only had them drop off once, but I had 35 drop off at once, which was no fun.... that’s why I replaced them, unmounting them all for rejoining put me over the edge...
I replaced them with the one @ogiewon had listed in the post above this. They work great for me
Thanks for that info Dan. In my small house they don't have to go through a repeater to join as every device can hit the hub without a repeater except one... my mail box sensor.
Thanks for clearing up my confusion. Sorry if I raised anyone’s anxiety levels
OHHHH you'll burn in hell for that one @SmartHomePrimer. Resistance is futile.
I am happy to know that it just won't join through a repeater. I have no more than 20 feet in any direction of my hub, so I'll be fine, I think.
The fire’s already lit. Just another log! ![]()
Actually, I'm glad you mentioned it. We don't always think about those things. Should have done my due diligence on this one, but the V2's weren't selling with magnets and I wasn't sure what would work as a replacement.
It would be nice if things like this were mentioned on the Hubitat " List of Compatible Devices".
It's a matter of updating that with correct information. Then, what is the cutoff? What becomes TMI? Slippery slope.
I actually just had this happen yesterday for the first time, but I only have 16. Fortunately all were about at the stage that they were needing batteries replaced anyway, so I covered two birds with one stone. However I think I will go the same route and get some of the 3320-L's for standby for IF/When this ever happens again and swap them out at that time.
Right. Ittliterally a list.
It links to the Join and Reset instructions, but then that would be a muddied doc, not unlike the often difficult to read manufacturers instructions, instead of straight to the point, easy to follow guide for just that singular purpose.
