Hi, I have an iris v2 leak detector that paired with no problems but it doesn't seem to be working.
I have a rule set up to send a text if a leak is detected but when I simulate a leak by patching it on wet paper, it doesn't send a text and if I go into the device status it is still showing as dry.
The light on the sensor turns red so I know it is correctly detecting the leak but guitar is not showing it as wet.
Is it possible you either accidentally reset it or it "fell off" your Zigbee network for some reason? The only thing you can really try is pairing it again (being Zigbee, it should just reinitialize the existing device; no need to delete it in Hubitat), which I'd do in-place (i.e., where you plan to use it) to see if that helps, then keep an eye on it for a bit to see if it stays paired. You might also want to make sure the battery isn't running low.
Do the exact same thing you would do to pair it normally. Just don't remove it from Hubitat first.
Definitely a problem with the automation (or rule?) then. Make sure your number is in the correct format, that you haven't exceeded the 10/day limit, and consider alternative options for notifications (Pushover, Pushbullet, SmartThings if you have an account, or hopefully soon the Hubitat mobile app).
So you're saying do a hard reset on the device so I can pair it again? I would have to do this in order to repair it. What is the benefit to doing it this way? Does it recognize the device id and re-add it back in to all the rules and such?
I haven't received any texts so I should be fine with the limit.
I have that same leak sensor. It works great. Never falls off the network. How far away is yours from the hub? What kind of obstructions are in the way (line of sight)? How many repeaters do you have? Are there any bulbs paired directly to the hub that could be repeating (and subsequently dropping) the signal? What driver are you using?
Ok, so should be Generic Zigbee Moisture Sensor. You can’t see what the network map looks like without an Xbee. You can search for Xbee to find out everything you need to know about that.
What brand of bulbs are paired directly to the hub? That’s very likely your issue unless they’re Sengled only, which do not repeat signals and so cannot be the cause.
All of your guesses are 100% correct. You can certainly delete it if you want, but if you don't, it will keep it in all your automations, so you won't have to re-do them like you would if you excluded/reset and re-paired a Z-Wave device (Zigbee has a factory-set MAC that Hubitat will recognize when the device is re-paired, even though it's hub-assigned DNI will change). Doing it this way will save you that effort.
Those may be the issue. They do cause problems. Unscrew them, and see if the issue goes away. If not, keep the Osram unscrewed and re-pair the leak sensor to see if the performance is then normal.
If it’s resolved. Add an outlet as a repeater. Remove and pair the leak sensor again, then give the Zigbee mesh time (like maybe 24 hours just to be sure) before trying to reintroduce the bulbs.
That’s definitely going to be an issue. If the leak sensor has routed through the outlet, and then power is cut to the outlet, the leak sensor will drop.
No that’s it. The “programming” part is trivial. There’s a lot of posts there that’s will tell you exactly what you need to order, and exactly what settings to put in for both the PC and Mac versions of the software.
Everyone is intimidated by it (I was too) and everyone (myself included) comments on how simple it was once they try it.
Oh, and an Xbee is one of the best repeaters available if you want to use it that way as well.
