I am trying to pair a Iris keypad model KPD800.
What is the exact method to pair this device?
That is not a supported device. The V1 Iris devices that are supported are as follows:
The Iris v2 keypad however works great, if you can still find one on Ebay.
Hi @Terk ,
How do I pair an Iris v2 keypad to the Hubitat hub?
Go to Join and Reset Instructions - Hubitat Documentation
Then scroll down to V2 keypad for instructions.
Although I use Hubitat I wish they would have figured out a way to make this keypad work. I still have one.
Its located here... Did I miss something?
The v1 keypads actually work better than v2 or v3 or anything else.
I have been working on fixing a bug in v3 where you cant cancel water/smoke alarms or turn of alarms. Because the keypad doesn't function when its disarmed.
