Do you have a link? I can't find any of them that cheap.
Same seller that’s had all of the other Iris listings. Please note that there are no magnets with these.
Ah...those lots with no magnets.
I just got some of these and noticed it isn't recognised still (joins as device), maybe slipped through the cracks.
As mentioned above, works fine with Generic Contact Sensor (including temperature reading).
Manufacturer: iMagic by GreatStar
Product Name:
Model Number: 1116-S
deviceTypeId: 176
more...
manufacturer : iMagic by GreatStar
idAsInt : 1
inClusters : 0000,0001,0003,0020,0402,0500,0B05,FC01,FC02
endpointId : 01
profileId : 0104
application : 00
outClusters : 0003,0019
initialized : true
model : 1116-S
stage : 4
dev:202020-01-08 16:40:53.063 debugparse: listResult [[name:battery, value:100, descriptionText:Door Window Sensor - Bedroom 2 battery is 100%, unit:%]]
dev:202020-01-08 16:40:53.062 infoDoor Window Sensor - Bedroom 2 battery is 100%
dev:202020-01-08 16:40:53.060 debugzigbee.parseDescriptionAsMap-read attr: [raw:863C0100010A20002020, dni:863C, endpoint:01, cluster:0001, size:0A, attrId:0020, encoding:20, command:01, value:20, clusterInt:1, attrInt:32]
dev:202020-01-08 16:40:53.058 debugparse: read attr - raw: 863C0100010A20002020, dni: 863C, endpoint: 01, cluster: 0001, size: 0A, attrId: 0020, encoding: 20, command: 01, value: 20
dev:202020-01-08 16:40:53.038 debugparse: listResult [[name:temperature, value:25.89, descriptionText:Door Window Sensor - Bedroom 2 temperature is 25.89°C, unit:°C]]
dev:202020-01-08 16:40:53.037 debugparseReportAttributeMessage: Temp resultMap: [name:temperature, value:25.89, descriptionText:Door Window Sensor - Bedroom 2 temperature is 25.89°C, unit:°C]
dev:202020-01-08 16:40:53.035 infoDoor Window Sensor - Bedroom 2 temperature is 25.89°C
dev:202020-01-08 16:40:53.033 debugzigbee.parseDescriptionAsMap-read attr: [raw:863C0104020C0000291D0A, dni:863C, endpoint:01, cluster:0402, size:0C, attrId:0000, encoding:29, command:01, value:0A1D, clusterInt:1026, attrInt:0]
dev:202020-01-08 16:40:53.032 debugparse: read attr - raw: 863C0104020C0000291D0A, dni: 863C, endpoint: 01, cluster: 0402, size: 0C, attrId: 0000, encoding: 29, command: 01, value: 1D0A
dev:202020-01-08 16:40:44.229 debugparse: listResult []
dev:202020-01-08 16:40:44.225 debugzigbee.parseDescriptionAsMap-read attr: [raw:catchall: 0104 0402 01 01 0040 00 863C 00 00 0000 07 01 00, profileId:0104, clusterId:0402, clusterInt:1026, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:863C, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00]]
dev:202020-01-08 16:40:44.222 debugparse: catchall: 0104 0402 01 01 0040 00 863C 00 00 0000 07 01 00
dev:202020-01-08 16:40:44.196 debugparse: listResult []
dev:202020-01-08 16:40:44.193 debugzigbee.parseDescriptionAsMap-read attr: [raw:catchall: 0000 8021 00 00 0040 00 863C 00 00 0000 00 00 F200, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:863C, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[F2, 00]]
dev:202020-01-08 16:40:44.187 debugparse: catchall: 0000 8021 00 00 0040 00 863C 00 00 0000 00 00 F200
dev:202020-01-08 16:40:44.180 debugparse: listResult []
dev:202020-01-08 16:40:44.177 debugzigbee.parseDescriptionAsMap-read attr: [raw:catchall: 0104 0001 01 01 0040 00 863C 00 00 0000 07 01 86002100, profileId:0104, clusterId:0001, clusterInt:1, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:863C, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[86, 00, 21, 00]]
dev:202020-01-08 16:40:44.168 debugparse: catchall: 0104 0001 01 01 0040 00 863C 00 00 0000 07 01 86002100
dev:202020-01-08 16:40:44.158 debugparse: listResult []
dev:202020-01-08 16:40:44.156 debugzigbee.parseDescriptionAsMap-read attr: [raw:catchall: 0000 8021 00 00 0040 00 863C 00 00 0000 00 00 F000, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:863C, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[F0, 00]]
dev:202020-01-08 16:40:44.149 debugparse: catchall: 0000 8021 00 00 0040 00 863C 00 00 0000 00 00 F000
dev:202020-01-08 16:40:44.139 debugparse: listResult []
dev:202020-01-08 16:40:44.137 debugzigbee.parseDescriptionAsMap-read attr: [raw:catchall: 0104 0001 01 01 0040 00 863C 00 00 0000 07 01 00, profileId:0104, clusterId:0001, clusterInt:1, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:863C, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:07, direction:01, data:[00]]
dev:202020-01-08 16:40:44.131 debugparse: catchall: 0104 0001 01 01 0040 00 863C 00 00 0000 07 01 00
dev:202020-01-08 16:40:44.107 debugparse: listResult []
dev:202020-01-08 16:40:44.105 debugzigbee.parseDescriptionAsMap-read attr: [raw:catchall: 0000 8021 00 00 0040 00 863C 00 00 0000 00 00 EE00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:863C, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[EE, 00]]
dev:202020-01-08 16:40:44.099 debugparse: catchall: 0000 8021 00 00 0040 00 863C 00 00 0000 00 00 EE00
dev:202020-01-08 16:40:43.099 debugparse: listResult [[name:battery, value:100, descriptionText:Door Window Sensor - Bedroom 2 battery is 100%, unit:%]]
dev:202020-01-08 16:40:43.096 infoDoor Window Sensor - Bedroom 2 battery is 100%
dev:202020-01-08 16:40:43.095 debugzigbee.parseDescriptionAsMap-read attr: [raw:863C0100010A20002020, dni:863C, endpoint:01, cluster:0001, size:0A, attrId:0020, encoding:20, command:01, value:20, clusterInt:1, attrInt:32]
dev:202020-01-08 16:40:43.093 debugparse: read attr - raw: 863C0100010A20002020, dni: 863C, endpoint: 01, cluster: 0001, size: 0A, attrId: 0020, encoding: 20, command: 01, value: 20
dev:202020-01-08 16:40:43.044 debugparse: listResult [[name:temperature, value:25.89, descriptionText:Door Window Sensor - Bedroom 2 temperature is 25.89°C, unit:°C]]
dev:202020-01-08 16:40:43.043 debugparseReportAttributeMessage: Temp resultMap: [name:temperature, value:25.89, descriptionText:Door Window Sensor - Bedroom 2 temperature is 25.89°C, unit:°C]
dev:202020-01-08 16:40:43.041 infoDoor Window Sensor - Bedroom 2 temperature is 25.89°C
dev:202020-01-08 16:40:43.039 debugzigbee.parseDescriptionAsMap-read attr: [raw:863C0104020C0000291D0A, dni:863C, endpoint:01, cluster:0402, size:0C, attrId:0000, encoding:29, command:01, value:0A1D, clusterInt:1026, attrInt:0]
dev:202020-01-08 16:40:43.037 debugparse: read attr - raw: 863C0104020C0000291D0A, dni: 863C, endpoint: 01, cluster: 0402, size: 0C, attrId: 0000, encoding: 29, command: 01, value: 1D0A
dev:202020-01-08 16:40:43.028 debugparse: listResult []
dev:202020-01-08 16:40:43.026 debugzigbee.parseDescriptionAsMap-read attr: [raw:catchall: 0104 0500 01 01 0040 00 863C 00 00 0000 04 01 00, profileId:0104, clusterId:0500, clusterInt:1280, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:863C, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:202020-01-08 16:40:43.023 debugparse: catchall: 0104 0500 01 01 0040 00 863C 00 00 0000 04 01 00
dev:202020-01-08 16:40:43.004 debugparse: listResult []
dev:202020-01-08 16:40:43.002 debugzigbee.parseDescriptionAsMap-read attr: [raw:catchall: 0104 0500 01 01 0040 00 863C 00 00 0000 04 01 00, profileId:0104, clusterId:0500, clusterInt:1280, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:863C, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:202020-01-08 16:40:42.996 debugparse: catchall: 0104 0500 01 01 0040 00 863C 00 00 0000 04 01 00
dev:202020-01-08 16:40:40.190 warnconfigure...
dev:202020-01-08 16:40:33.740 warndescription logging is: true
dev:202020-01-08 16:40:33.738 warndebug logging is: true
Is this a Gen 3 contact sensor? I don't know that I've ever seen one. It's possible that the footprint was never added to the generic driver. Tagging @mike.maxwell to see if this needs to be added.
Anyone know why my Iris iL06 contact sensor keeps shutting off?
I found this under scheduled jobs on the device page
logsOff 2021-02-28 11:47:14 AM EST PENDING Once
I need to keep resetting the sensor to get it to report correctly. Works for a few minutes then just stops updating. Device shows whatever the last state it was in and just stays there.
How many zigbee repeaters do you have? How close is this contact sensor to the Hubitat?
This line in the logs simply indicates that the Debug Logging feature is scheduled to automatically disabled after 30 minutes. It does not indicate any cause for concern.
To get your device to properly report status updates:
- Make sure it has a fresh battery installed (just in case)
- Click the CONFIGURE button on the device details page, to tell the device when and how to report status updates to the hub.
When I click on the configure button nothing happens.
New battery reporting 100%
Correct. You won't typically 'see' anything occur, but behind the scenes zigbee messages are being sent to the device to 'configure' it properly.
Sorry a noob. I've tried removing and rediscovering the device several times. Each time it works for about 10 min then stops reporting. When I open and close the door the LED on the sensor goes on but nothing on the device page
Tell us a little more about your Zigbee network, as @aaiyar mentioned earlier...
Also, have you read How to Build a Solid Zigbee Mesh - Hubitat Documentation ?
You could have WiFi interference depending on what Zigbee and WiFi channels are in use. You could have a weak signal between the hub and the sensor. Lots of things to troubleshoot, but nothing that we all haven't had to deal with over the years. Lots of great folks here in the community willing to help get things sorted out.
Have multiple Zigbee lights that seem to work okay. This sensor is on my screen room door. There are 2 zigbee light bulbs outside the door that seem to work fine.
Zigbee channel 0x14 (20) 20
Router WiFi is on Auto channel 2.4 and 5 Ghz
Best to set your Router WiFi 2.4GHz radio to Channel 1 to avoid any issues with Zigbee channel 20.
What type of Zigbee lights/bulbs are these? Many Zigbee bulbs were originally designed to use ZLL zigbee networking, and thus make poor ZHA repeater devices.
As I think @ogiewon suspects, it could be the lights. There are many threads here about the poor function of zigbee lights as repeaters for devices other than similar bulbs. Two culprits of particular note are GE Links, and Cree Connected.
Sorry about the delay. Honey do projects
Most of the bulbs are several years old. A few Sengled others I don't even remember the brand. I ported over from Wink. Just show up as Generic Zigbee.
I did change the WiFi channel on my router to 1. Results: no change.
I bought 10 of these sensors (more than I need but lot of 10 was cheap on ebay)
I'm going to pair another one and just leave it between the hub and the back door as a repeater.
The hub is about 20 ft from the sensor but through a frame wall about 1ft wide with drywall on both sides. Can't understand why it should be a bad signal.
Thanks for everyone's help. Soooo much better than Wink
Battery powered devices (Zigbee or Z-Wave) are not repeaters for their respective networks. Repeaters are typically devices that are plugged into an outlet, that have lots of power to spare. Battery powered devices would eat through their batteries in no time if they had to act as repeaters.
Check out the brands of smart bulbs you have, aside from the Sengleds. The Sengleds are fine and will not cause any issues. However, Cree and GE Link bulbs are notorious for wrecking a Zigbee HA mesh network.
If you don't have any other devices that are Zigbee repeaters, I would suggest you buy some IKEA Tradfri Outlets or dedicated IKEA Tradfri Zigbee repeaters to help build a strong mesh. Other options include Centralite and INNR Zigbee outlets. I personally have about 8 older Iris 3210-L outlets spread throughout my house, which have been very stable and reliable. Unfortunately, they are no longer manufactured.
Thanks again. I'll look for a repeater.
Have 2 Sylvania Smart Color tunable bulbs on the screen room outside of where the sensor is. No trouble communicating with the hub
