Iphone presence between multiple hubs/sites - iOS 18 breaking existing presence detector
While you wait for multi-geofence in the Wubitat app, may I suggest you look at Locative on IOS, this little app can have as many locations as you want and since the locations are tied to webhooks with MakerAPI cloud endpoints, you can send the info to multiple hubs on the same setup. Check the below link for very detailed setup instructions. Then repeat at the second location. When I had 2 locations, I used this method and it was very reliable, now that I sold my main home and now live in the country cabin, I still use it.
I will also be trying to use to detect if I'm on my way home or away from home by using 3-4 concentric circles around my house, this way in winter, I will be able to automate my thermostats to go up when it determines that I'm on my way home and vice-versa instead of just relying on the single circle. Also if I go to the corner store, it won't change anything unless I move out farther than that, etc.
Your imagination is the only limit to what you can do with geofencing using this app :wink:
