IP or Wyze Cameras
Hi All,
C7 model. I already have 3 wyze cameras reporting to dashboard. I want to mount a tablet next to front door to control camera. I would like the camera on the hubitat dashboard and allow use of microphone. What are your thoughts ? Anyone else doing this or should I just load wyze on the tablet by itself ?
Sand
Check out the following post for help troubleshooting problems and gathering details that will help others to identify and solve the problem you are experiencing: ‼ READ FIRST - Before Posting in Get Help
wyze cameras do not support external web based streams outside of their app
You can flash the wyze cam with rtsp firmware. That's for v2 cams and the pan-tilt of the same vintage. I don't know the situation for v3 cams. I've run it, but it's too laggy for me - a general rtsp issue. It's also a pain to flash onto a pan-tilt - an extra eyeball would help.
I would not attempt to make my own doorbell camera unless it's something you want to do for knowledge and are willing to spend a lot of time on it. I think it will be more money than a commercial door bell cam.
Thanks all will probably just use wyze app on the tablet then probably be easiest
