So given all the instability with the HE Homekit app, I decided to go nuclear. However, I'm now unable to add the Hubitat bridge as an accessory. Here's what I did;
In Apple Home app I removed the original Hubitat bridge (~34 accessories).
Did "reset QR and code pairing code"
Restarted integration
Scanned new QR code in Home app. No popups about an uncertified accessory....would just sit there and spin trying to add the bridge. Finally times out after a few minutes and the operation fails.
Reset Hubitat QR code again
Rebooted Hubitat hub
Scanned QR code again in Home app. Immediately pops up with the uncertified accessory warning. Then it immediately errors out with: This accessory cannot be used with HomeKit.
Can you PM me the hub id? I'll take a look at the engineering logs.
Are modes enabled at the bottom of the integration? Try disabling that first.
If that doesn't work and while we're getting to the bottom of it... you can try unchecking all devices except one, add ingthe accessory, and then start adding devices one at a time. Sometimes a particular device can trigger this behavior.
Previously I had these accessory categories: contact sensor, dimmer, motion sensor, outlet, switch, water sensor.
Phase 1 test:
Unchecked many devices but left these categories: contact sensor, motion sensor, water sensor
After I unchecked those devices, I restarted integration. Scanned QR code in Home app and it quickly failed saying basically unable to add bridge. Then reset QR code again and rebooted Hubitat. QR code then immediately scanned, and is now guiding me through adding each of the exposed accessories. I cancelled (wanted to add more devices and re-test).
Phase 2 test:
Checked all dimmers and outlets. Reset QR code, rebooted hub. Home app added bridge and is walking me though accessory setup. Note: Only accessories NOT selected at this point are all "switch" devices.
For "switch" devices I had 5 I was trying to use in Homekit. Two physical zwave outlets, one virtual simple switch, and two presence virtual sensors. The two virtual presence sensors were recent additions, so maybe one or both of those are causing my problems? For the time being I did check the two physical outlets and the simple virtual switch. The two presence sensors are NOT checked. I'll reconfigure Home, re setup my automations, and try it without presence devices.
Update: My "simple" virtual switch just went "no response" and I wasn't doing anything in the Home app with that accessory. Now its back to a normal state after a minute.
Update 2: Random set of Hubitat devices are now flapping. From lights, outlets, to virtual switches. Not doing anything in the Home app except observing accessory states.
Well I bit the bullet and updated the architecture. BIG MISTAKE. Mine works fine. But can't get my wife's to work. Deleted home on hers. Sent invitation again. She gets the invitation, hits accept and after several minutes says it can't accept invitation. All device firmware is up to date with same versions as mine. I'm gonna be in trouble when she gets up and sees I messed her phone up.
@gopher.ny So everything in my Hubitat HK app is flapping like crazy. I moved a number of accessories back over to the Homebridge v2 app and they are rock solid in the Apple Home app.
After repeated re-boots, re-tries, I finally got my wife's phone to accept invitation and show the devices. But she didn't show up on mine under home settings as she previously did. Talked to Apple, no help there. Finally re-booted everything and it all came back up as before. Still not sure what was going on. Note to self: Don't do anymore updates...
Downloaded, rebooted, all 25 Hubitat accessories are "no response". Toggled relaxed security (was already relaxed..just toggled for the fun of it), restarted the integration a few times, and rebooted the whole Hub once more. For a brief period only 3 accessories were no response, but now all 25 are back to 'no response'. So instead of regular flapping, they seem to be stuck in the 'no response' state.
Quick update....devices are back to flapping. When everything appears to be settled down, and I toggle a Hubitat accessory a few times like a light then after a few taps will always go 'no response'.
Iāve been running 16.2 for a day or two on my HomePod-mini , ipad and iPhone with hubitat on 2.3.4.120 with no issues . I only have the one HomePod as my hub with C-5 & C-7 hubitat hubs. I updated 2.3.4.120 but never opened the hubitat after the reboot.
Other than the issue with getting my wifeās phone connected mine has been solid. Iāve turned things on/off repeatedly trying to break it. No problems. I have 2 minis. I did have an issue when I enabled modes. I didnāt mess with that too much as I didnāt need it. I turned it back off and everything is fine.
