Invalid operand type
I am using a Zooz Zen15 and it is reporting power as a String. The rule engine obviously wont work. How do I fix this?
invalid operand type for 0.000(string) < 5.0(number)
The number could be converted to a numeral format in the driver - are you using the built-in (Hubitat) driver or a community driver? This will determine who can fix the issue… Also, you could switch from one to the other to see if it resolves the issue for you.
Try this driver, see if it makes a difference: [DRIVER] Zooz Smart Plugs Advanced (ZEN04 / ZEN05 / ZEN14 / ZEN15)
Also, possibly you need to delete the attributes and let them be re-created with a proper driver. If you switch to the driver/type called "Device" there is a button to delete current state. Switch back to the normal driver and they will get repopulated as reports come in.
Is that rule trying to trigger every 2-3 milliseconds?
Good point, the reporting on that ZEN15 is little aggressive, that's going to kill the mesh, I would adjust that a little bit.
