Well...I built this out a little bit.
Nothing revolutionary and it's a bit ugly, but I added a bunch of different unit-based dispensing options, plus two 'custom' fills.
Here's the whole thing. I think it's ready to update in GitHub.
If someone is better at this than me and could convert the many unit-based commands from individual actions into an ENUM where each list item still accepts an integer input, this could be nearly 1:1 with the Delta portal.
Copyright 2023 - SebastienViel
Licensed under the Apache License, Version 2.0 (the "License");
you may not use this file except in compliance with the License.
You may obtain a copy of the License at
http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an "AS IS" BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
limitations under the License.
This driver was written with the help of OpenAI, tomw and the hubitat community based on the following script from veelar:
https://gist.github.com/velaar/4e18a200c1db7b06109a3fd840838684
Change history:
1.0 - SebastienViel - Initial release.
1.1 - SebastienViel - Removed "Driver" from the driver name.
1.2 - TomW - Added option to dispence a specific quantity and a query for information (logged for now) and other fixes.
1.3 - SebastienViel - Added sending events with on/off/dispense and fixed logging and definitions
1.4 - TomW & SebastienViel - Multiple updates
1.5 - SebastienViel - Updated some of the labels and did a bit of OCD code clean-up...
1.6 - SebastienViel - Added a delay to the off command when dispensing a specific quantity
1.7 - TomW - Updated the delay code to a better approach that would prevent potential issues
1.7 - SebastienViel - Updated Debug Logging
1.8 - TomW - Added a way to display usage data
1.9 - SebastienViel - Fixed Logging when it shouldn't
1.10 - TomW - Update Usage Refresh code to show previous day for daily value since current day is always 0
1.11 - SebastienViel - Updated Usage Refresh code to show previous day when the value received was 0
1.12 - green.aarond - Updated with non-legacy deltafaucet device URL
1.13 - green.aarond - Added dispense options for other units (cL, dL, L, fl oz, c, pt, qt, gal) + 'custom' options to fill a glass or a coffee pot
//import groovy.json.JsonSlurper
//import groovy.transform.Field
metadata
definition(
name: "Delta VoiceIQ Faucet",
namespace: "SebastienViel",
author: "Sébastien Viel and TomW",
importUrl: "https://raw.githubusercontent.com/SebastienViel/Hubitat_Delta_Faucet/main/Hubitat_Delta_Faucet_Driver"
capability "Refresh"
capability "Switch"
attribute "usageLastDay", "number"
attribute "usageLastWeek", "number"
attribute "usageLastMonth", "number"
attribute "usageLastYear", "number"
command "saveToken", ["Token"]
command "dispense_fl_oz", [[name: "Fluid Ounces", title: "Dispense fl oz", type: "NUMBER", description: "Input number of fluid ounces to dispense (integers only)"]] //30 mL
command "dispense_c", [[name: "Cups", title: "Dispense cups", type: "NUMBER", description: "Input number of cups to dispense (integers only)"]] //237 mL
command "dispense_pt", [[name: "Pints", title: "Dispense pints", type: "NUMBER", description: "Input number of pints to dispense (integers only)"]] //473 mL
command "dispense_qt", [[name: "Quarts", title: "Dispense quarts", type: "NUMBER", description: "Input number of quarts to dispense (integers only)"]] //946 mL
command "dispense_gal", [[name: "Gallons", title: "Dispense gallons", type: "NUMBER", description: "Input number of gallons to dispense (integers only)"]] //3785 mL
command "dispense_mL", [[name: "Milliliters", title: "Dispense mL", type: "NUMBER", description: "Input number of milliliters to dispense (integers only)"]]
command "dispense_cL", [[name: "Centiliters", title: "Dispense cL", type: "NUMBER", description: "Input number of centiliters to dispense (integers only)"]] //10 mL
command "dispense_dL", [[name: "Deciliters", title: "Dispense dL", type: "NUMBER", description: "Input number of deciliters to dispense (integers only)"]] //100 mL
command "dispense_L", [[name: "Liters", title: "Dispense L", type: "NUMBER", description: "Input number of liters to dispense (integers only)"]] //1000 mL
command "fill_glass", [[name: "Fill Glass", title: "Fill Glass", description: "Dispense 1 glass (12 fl oz) of water"]] //355 mL
command "fill_coffee_pot", [[name: "Fill Coffee Pot", title: "Fill Coffee Pot", description: "Dispense 4 cups (32 fl oz) of water"]] //943 mL
command "queryUsageReport", [[name: "Time interval", title: "Query Usage Report", type:"ENUM", constraints: knownTimePeriods().keySet()]]
preferences
input(name: "delta_device_id", type: "text", title: "Delta Device ID", description: "Enter Delta Device ID", defaultValue: "")
input(name: "logEnable", type: "bool", title: "Enable debug logging", defaultValue: true)
def installed()
log.debug "installed"
def updated()
log.debug "updated"
def on()
toggleWater("on")
def off()
toggleWater("off")
def refresh()
def resp
knownTimePeriods().each
resp = queryUsageReport(it.key)
// daily usage is zero for current day, so go to previous day only for that case
//def dataOffset = (it.key == "usageLastDay") ? 2 : 1
def dataOffset = 1
def value = resp?.getAt(resp.size() - dataOffset)
if(logEnable){log.debug "${it.key} key value is ${value} for response ${resp.size()} less a ${dataOffset} offset"}
if(value == 0)
value = resp?.getAt(resp.size() - (dataOffset + 1))
if(logEnable){log.debug "Retrying since value was 0 - ${it.key} key value is ${value} for response ${resp.size()} less a ${dataOffset + 1} offset"}
sendEvent(name: it.key, value: value)
def knownTimePeriods()
def periods = [ usageLastDay: 0, usageLastWeek: 1, usageLastMonth: 2, usageLastYear: 3 ]
return periods
def queryUsageReport(interval)
interval = knownTimePeriods()?.getAt(interval)
try
if(logEnable){log.debug "Getting Usage Report for ${interval} interval."}
def response = httpExec("GET", "UsageReport?deviceId=${delta_device_id}&interval=${interval}")
if(response?.status?.toInteger() == 200)
if (logEnale){log.info "Usage Report = ${response.data}"}
return response.data?.retObject?.datasets?.getAt(0)?.data
else
log.error "Usage Report ${interval} failed: ${response.status}"
catch(Exception e)
log.error "Error Usage Report: ${e.message}"
def saveToken(token)
device.updateDataValue("token", token)
def currentToken()
return device.getDataValue("token")
private toggleWater(String toggle)
try
if (logEnable){log.debug "Preparing the ${toggle} command to send to Delta."}
def response = httpExec("POST", "toggleWater?deviceId=${delta_device_id}&toggle=${toggle}")
if (logEnable){log.debug "Response Status (from toggleWater): ${response.status}"}
if (logEnable){log.debug "Response Data (from toggleWater): ${response.data}"}
sendSwitchState(toggle)
// sendEvent(name: "switch", value: toggle, descriptionText: "${device.displayName} is ${toggle}")
if (logEnable){log.debug "Toggle water ${toggle} successful"}
else
log.error "Toggle water ${toggle} failed: ${response.status}"
catch(Exception e)
log.error "Error toggling water: ${e.message}"
private dispense_mL(mL_toDispense)
try
if (logEnable){log.debug "Preparing the ${mL_toDispense} mL to dispense command to send to Delta."}
def response = httpExec("POST", "dispense?deviceId=${delta_device_id}&milliliters=${mL_toDispense}")
if (logEnable){log.debug "Response Status (from dispense_mL): ${response.status}"}
if (logEnable){log.debug "Response Data (from dispense_mL): ${response.data}"}
if (logEnable){ log.debug "Dispense mL ${mL_toDispense} successful" }
//sendEvent(name: "switch", value: "on", descriptionText: "${device.displayName} is on")
if (logEnable){ log.debug "mL_toDispense is set to ${mL_toDispense}"}
def pauseDuration = 10
pauseDuration = mL_toDispense.toInteger() / 70
if (logEnable){ log.debug "Pause duration is set to ${pauseDuration}"}
if(pauseDuration.toInteger() > 300)
pauseDuration = 300
if (logEnable){ log.debug "Pause duration was changed to ${pauseDuration}"}
pauseDuration = pauseDuration.intValue()
sendSwitchState("on", pauseDuration)
else
log.error "Dispense mL failed: ${response.status}"
catch(Exception e)
log.error "Error dispensing water: ${e.message}"
private dispense_fl_oz(fl_oz_toDispense)
try
def fl_oz_in_mL = 30
fl_oz_in_mL = fl_oz_toDispense.toInteger() * 30
if (logEnable){log.debug "Preparing the ${fl_oz_in_mL} mL to dispense command to send to Delta (calculated from ${fl_oz_toDispense} fl. oz.)."}
def response = httpExec("POST", "dispense?deviceId=${delta_device_id}&milliliters=${fl_oz_in_mL}")
if (logEnable){log.debug "Response Status (from dispense_fl_oz): ${response.status}"}
if (logEnable){log.debug "Response Data (from dispense_fl_oz): ${response.data}"}
if (logEnable){ log.debug "Dispense ${fl_oz_toDispense} fl. oz. (sent as ${fl_oz_in_mL} mL) successful" }
if (logEnable){ log.debug "mL_toDispense is set to ${fl_oz_in_mL} (calculated from ${fl_oz_toDispense} fl. oz.)"}
pauseDuration = fl_oz_in_mL.toInteger() / 70
pauseDuration = 300
else
log.error "Dispense fl oz failed: ${response.status}"
catch(Exception e)
private dispense_c(c_toDispense)
try
def c_in_mL = 237
c_in_mL = c_toDispense.toInteger() * 237
if (logEnable){log.debug "Preparing the ${c_in_mL} mL to dispense command to send to Delta (calculated from ${c_toDispense}c)."}
def response = httpExec("POST", "dispense?deviceId=${delta_device_id}&milliliters=${c_in_mL}")
if (logEnable){log.debug "Response Status (from dispense_c): ${response.status}"}
if (logEnable){log.debug "Response Data (from dispense_c): ${response.data}"}
if (logEnable){ log.debug "Dispense ${c_toDispense}c (sent as ${c_in_mL} mL) successful" }
if (logEnable){ log.debug "mL_toDispense is set to ${c_in_mL} (calculated from ${c_toDispense}c)"}
pauseDuration = c_in_mL.toInteger() / 70
pauseDuration = 300
else
log.error "Dispense c failed: ${response.status}"
catch(Exception e)
private dispense_pt(pt_toDispense)
try
def pt_in_mL = 473
pt_in_mL = pt_toDispense.toInteger() * 473
if (logEnable){log.debug "Preparing the ${pt_in_mL} mL to dispense command to send to Delta (calculated from ${pt_toDispense}pt)."}
def response = httpExec("POST", "dispense?deviceId=${delta_device_id}&milliliters=${pt_in_mL}")
if (logEnable){log.debug "Response Status (from dispense_pt): ${response.status}"}
if (logEnable){log.debug "Response Data (from dispense_pt): ${response.data}"}
if (logEnable){ log.debug "Dispense ${pt_toDispense}pt (sent as ${pt_in_mL} mL) successful" }
if (logEnable){ log.debug "mL_toDispense is set to ${pt_in_mL} (calculated from ${pt_toDispense}pt)"}
pauseDuration = pt_in_mL.toInteger() / 70
pauseDuration = 300
else
log.error "Dispense pt failed: ${response.status}"
catch(Exception e)
private dispense_qt(qt_toDispense)
try
def qt_in_mL = 946
qt_in_mL = qt_toDispense.toInteger() * 946
if (logEnable){log.debug "Preparing the ${qt_in_mL} mL to dispense command to send to Delta (calculated from ${qt_toDispense}qt)."}
def response = httpExec("POST", "dispense?deviceId=${delta_device_id}&milliliters=${qt_in_mL}")
if (logEnable){log.debug "Response Status (from dispense_qt): ${response.status}"}
if (logEnable){log.debug "Response Data (from dispense_qt): ${response.data}"}
if (logEnable){ log.debug "Dispense ${qt_toDispense}qt (sent as ${qt_in_mL} mL) successful" }
if (logEnable){ log.debug "mL_toDispense is set to ${qt_in_mL} (calculated from ${qt_toDispense}qt)"}
pauseDuration = qt_in_mL.toInteger() / 70
pauseDuration = 300
else
log.error "Dispense qt failed: ${response.status}"
catch(Exception e)
private dispense_gal(gal_toDispense)
try
def gal_in_mL = 3785
gal_in_mL = gal_toDispense.toInteger() * 3785
if (logEnable){log.debug "Preparing the ${gal_in_mL} mL to dispense command to send to Delta (calculated from ${gal_toDispense}gal)."}
def response = httpExec("POST", "dispense?deviceId=${delta_device_id}&milliliters=${gal_in_mL}")
if (logEnable){log.debug "Response Status (from dispense_gal): ${response.status}"}
if (logEnable){log.debug "Response Data (from dispense_gal): ${response.data}"}
if (logEnable){ log.debug "Dispense ${gal_toDispense}gal (sent as ${gal_in_mL} mL) successful" }
if (logEnable){ log.debug "mL_toDispense is set to ${gal_in_mL} (calculated from ${gal_toDispense}gal)"}
pauseDuration = gal_in_mL.toInteger() / 70
pauseDuration = 300
else
log.error "Dispense gal failed: ${response.status}"
catch(Exception e)
private dispense_cL(cL_toDispense)
try
def cL_in_mL = 10
cL_in_mL = cL_toDispense.toInteger() * 10
if (logEnable){log.debug "Preparing the ${cL_in_mL} mL to dispense command to send to Delta (calculated from ${cL_toDispense} cL)."}
def response = httpExec("POST", "dispense?deviceId=${delta_device_id}&milliliters=${cL_in_mL}")
if (logEnable){log.debug "Response Status (from dispense_cL): ${response.status}"}
if (logEnable){log.debug "Response Data (from dispense_cL): ${response.data}"}
if (logEnable){ log.debug "Dispense ${cL_toDispense} cL (sent as ${cL_in_mL} mL) successful" }
if (logEnable){ log.debug "mL_toDispense is set to ${cL_in_mL} (calculated from ${cL_toDispense} cL)"}
pauseDuration = cL_in_mL.toInteger() / 70
pauseDuration = 300
else
log.error "Dispense cL failed: ${response.status}"
catch(Exception e)
private dispense_dL(dL_toDispense)
try
def dL_in_mL = 100
dL_in_mL = dL_toDispense.toInteger() * 100
if (logEnable){log.debug "Preparing the ${dL_in_mL} mL to dispense command to send to Delta (calculated from ${dL_toDispense} dL)."}
def response = httpExec("POST", "dispense?deviceId=${delta_device_id}&milliliters=${dL_in_mL}")
if (logEnable){log.debug "Response Status (from dispense_dL): ${response.status}"}
if (logEnable){log.debug "Response Data (from dispense_dL): ${response.data}"}
if (logEnable){ log.debug "Dispense ${dL_toDispense} dL (sent as ${dL_in_mL} mL) successful" }
if (logEnable){ log.debug "mL_toDispense is set to ${dL_in_mL} (calculated from ${dL_toDispense} dL)"}
pauseDuration = dL_in_mL.toInteger() / 70
pauseDuration = 300
else
log.error "Dispense dL failed: ${response.status}"
catch(Exception e)
private dispense_L(L_toDispense)
try
def L_in_mL = 100
L_in_mL = L_toDispense.toInteger() * 100
if (logEnable){log.debug "Preparing the ${L_in_mL} mL to dispense command to send to Delta (calculated from ${L_toDispense} L)."}
def response = httpExec("POST", "dispense?deviceId=${delta_device_id}&milliliters=${L_in_mL}")
if (logEnable){log.debug "Response Status (from dispense_L): ${response.status}"}
if (logEnable){log.debug "Response Data (from dispense_L): ${response.data}"}
if (logEnable){ log.debug "Dispense ${L_toDispense} L (sent as ${L_in_mL} mL) successful" }
if (logEnable){ log.debug "mL_toDispense is set to ${L_in_mL} (calculated from ${L_toDispense} L)"}
pauseDuration = L_in_mL.toInteger() / 70
pauseDuration = 300
else
log.error "Dispense L failed: ${response.status}"
catch(Exception e)
private fill_glass(glass_fill)
try
def glassful = 355
if (logEnable){log.debug "Preparing the ${glassful} mL to dispense command to send to Delta (one 12 fl. oz. glass of water)."}
def response = httpExec("POST", "dispense?deviceId=${delta_device_id}&milliliters=${glassful}")
if (logEnable){log.debug "Response Status (from fill_glass): ${response.status}"}
if (logEnable){log.debug "Response Data (from fill_glass): ${response.data}"}
if (logEnable){ log.debug "Dispense 1 glass (sent as ${glassful} mL) successful" }
if (logEnable){ log.debug "mL_toDispense is set to ${glassful} (one 12 fl. oz. glass of water)"}
pauseDuration = glassful.toInteger() / 70
pauseDuration = 300
else
log.error "Fill glass failed: ${response.status}"
catch(Exception e)
private fill_coffee_pot(coffee_pot_fill)
try
def coffeepot = 943
if (logEnable){log.debug "Preparing the ${coffeepot} mL to dispense command to send to Delta (32 fl. oz. of water; about 1 coffee pot)."}
def response = httpExec("POST", "dispense?deviceId=${delta_device_id}&milliliters=${coffeepot}")
if (logEnable){log.debug "Response Status (from fill_coffee_pot): ${response.status}"}
if (logEnable){log.debug "Response Data (from fill_coffee_pot): ${response.data}"}
if (logEnable){ log.debug "Dispense 1 coffee pot (sent as ${coffeepot} mL) successful" }
if (logEnable){ log.debug "mL_toDispense is set to ${coffeepot} (32 fl. oz. of water; about 1 coffee pot)"}
pauseDuration = coffeepot.toInteger() / 70
pauseDuration = 300
else
log.error "Fill coffee pot failed: ${response.status}"
catch(Exception e)
def sendSwitchState(value, timeout = null)
unschedule(sendSwitchState)
// set presence to incoming state
sendEvent(name: "switch", value: value, descriptionText: "${device.displayName} is off")
if (logEnable) {log.debug "Timeout delay is set to ${timeout} seconds."}
if(null != timeout)
// if timeout reached, assume "off" is indicated state
if (logEnable) {log.debug "Set sendSwitchState to run in ${timeout} seconds."}
runIn(timeout, sendSwitchState, [data: "off"])
if (logEnable) {log.debug "Switch State updated to ${value}."}
def httpExec(operation, String path)
def result = null
def httpClosure =
{ resp ->
result = resp
def httpOp
switch(operation)
case "POST":
httpOp = this.delegate.&httpPost
break
case "GET":
httpOp = this.delegate.&httpGet
break
def deltaToken = "Bearer ${currentToken()}"
def apiUrl = "https://device.deltafaucet.com/api/device/" + path
def headers =
'Authorization': deltaToken, 'User-Agent': 'Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/110.0.0.0 Safari/537.36',
'Referer': 'https://device.deltafaucet.com/'
if (logEnable){log.debug "Sending the ${operation} for the command to be executed."}
httpOp(uri: apiUrl, headers: headers, httpClosure)
return result
