Installed several lumi zwave device (https://lumi.vn/en/devices.html)
The device was detected but I can't find the appropriate device.
When I try setting zwave generic button - it looks like doesn't working well.
In addition I can';t tell it how many buttons I have in the device.
Lumi devices aren't on the list of compatible devices.
https://docs.hubitat.com/index.php?title=List_of_Compatible_Devices
If you can't find a community driver here on the forum and one of the Generic drivers doesn't work then there's not much that can be done. But since it's z-wave, you should be able to use one of the Generic Drivers.
Tell Lumi if they send me the devices I will write drivers for them.
Wonโt work in your region @codahq
Not only would the frequency be wrong but they run on 220V. I was mostly being a sea fish. Or facetious. I didn't think @9999341 would be in any position to have them send me devices either.
That being said these look suspiciously familiar to some of the aliexpress Z-Wave devices that do have US and 110V counterparts. And some of may even have drivers that could work with these.
Everything is made in china ![]()
I don't know that you can. I believe that Hubitat only support Z-wave Central Scene button devices which it appears that this device doesn't support. This switch uses group associations to send commands directly to other z-wave devices without a central controller.
The seller told me that someone did connect it to HomeAssistant, and I know it can be connected to Fibaro Home Center 2, so I believe it can be connected to HE as well.
Why would you assume that because you can connect it to HA or a Fibaro controller that you can connect it to HE? I don't understand the logic there. Did the seller tell you what driver you should use for HE?
Yep.. it will work.. I did a similar driver.. it supports multichannel encap and multichannel association
But you will have to write a driver for it..
@bcopeland, May you please publish/send you driver?
I believe that based on it and with some guidelines I might manage (Even though I don't know groovy yet)
Itโs the touch panel driver and child
