I installed a couple of WD500Z-1 dimmer switches. Before doing so I found a driver on ST that had a fingerprint for a sister dimmer from the one installed.
I added the WD500Z-1 fingerprint data and loaded it into HE ( I also made the porting changes required)
When The WD500Z-1 is discovered it is identified as "other". When I select the above ST in "TYPE" it works fine.
Is my assumption that adding the new dimmer data to the drive was all that is needed?
BTW why is the device list data in decimal for type, ID and MFG, but the in clusters is in hex?
metadata {
definition(name: "Z-Wave Dimmer Switch Generic", namespace: "hubitat", author: "SmartThingsMod", ocfDeviceType: "oic.d.light", runLocally: true, minHubCoreVersion: '000.019.00012', executeCommandsLocally: true) {
capability "Switch Level"
capability "Actuator"
capability "Health Check"
capability "Switch"
capability "Polling"
capability "Refresh"
capability "Sensor"
capability "Light"
fingerprint inClusters: "0x26", deviceJoinName: "Z-Wave Dimmer"
fingerprint mfr: "001D", prod: "1902", deviceJoinName: "Z-Wave Dimmer"
fingerprint mfr: "001D", prod: "3301", model: "0001", deviceJoinName: "Leviton Dimmer Switch"
fingerprint mfr: "001D", prod: "3201", model: "0001", deviceJoinName: "Leviton Dimmer Switch"
fingerprint mfr: "001D", prod: "1B03", model: "0334", deviceJoinName: "Leviton Universal Dimmer"
fingerprint mfr: "011A", prod: "0102", model: "0201", deviceJoinName: "Enerwave In-Wall Dimmer"
fingerprint mfr: "001D", prod: "1001", model: "0334", deviceJoinName: "Leviton 3-Speed Fan Controller"
fingerprint mfr: "001D", prod: "0602", model: "0334", deviceJoinName: "Leviton Magnetic Low Voltage Dimmer"
fingerprint mfr: "001D", prod: "0401", model: "0334", deviceJoinName: "Leviton 600W Incandescent Dimmer"
fingerprint mfr: "0111", prod: "8200", model: "0200", deviceJoinName: "Remotec Technology Plug-In Dimmer"
fingerprint mfr: "1104", prod: "001D", model: "0501", deviceJoinName: "Leviton 1000W Incandescant Dimmer"
fingerprint mfr: "0063", prod: "4944", model: "3034", deviceJoinName: "GE In-Wall Smart Fan Control"
fingerprint mfr: "0063", prod: "4944", model: "3131", deviceJoinName: "GE In-Wall Smart Fan Control"
fingerprint mfr: "001A", prod: "4449", model: "0101", deviceJoinName: "Eaton RF Master Dimmer"
fingerprint mfr: "001A", prod: "4449", model: "0003", deviceJoinName: "Eaton RF Dimming Plug-In Module"
fingerprint mfr: "0086", prod: "0103", model: "0063", deviceJoinName: "Aeotec Smart Dimmer 6"
fingerprint mfr: "014F", prod: "5744", model: "3530", deviceJoinName: "GoControl In-Wall Dimmer"
fingerprint mfr: "014F", prod: "4457", model: "3034", deviceJoinName: "GoControl In-Wall Dimmer" // added for our WD500Z-1 not sure if it will work
} // --- end of metadata ---
WD500Z-1 Dimmer after installation
deviceType: 17495 <- decmial
inClusters: 0x26,0x2B,0x2C,0x27,0x73,0x70,0x86,0x72
deviceId: 12340 <- decmial
manufacturer: 335 <- decmial
