I just purchased this switch as I needed a switch that did not require a neutral wire in this particular location in my home. First strange issue was the light flickering and weird lights on the dimmer itself. I have a fixed led module ceiling light, it is not a light bulb that can be changed. I think i made some headway by setting the light level to a certain level.
I have seen in some forums that users recommend an actiontec bypass to fix the flickering issues.
Secondly, I wanted to know if there is an easy way to set the switch to on/off only. I do not want it to dim off or dim on. Lastly, I would like to set a fixed on and fixed off level.
I dont know if the bypass will fix everything, but if not i would like to set these limits.
Lastly, I am using default drivers from hubitat. I would like to use the second button on the switch.
