I installed an Inovelli LZW30 Black switch yesterday for our outdoors lights. It's working well, This is my first time using a Hubitat, and I was able to set this up no problem.
I do have a question though...the LED indicator on switch itself is always blue. I was wondering if it's possible to change that to "red" when off, and "blue" when on? Going through settings and messing around with Rule Editor doesn't seem to work for me.
I also see two options of the physical switch. One is "Inovelli Switch LZW30 (LED Color)" and another is "Outdoor Lights - Front".
The Inovelli driver creates a child device (by default Inovelli Switch LZW30 (LED Color))for the LED. If you target that with Simple Rules, Rule Machine, webCore, etc. you should be able to set the colors as desired.
Short story: I came from Wink and their app showed which automation executed at what time. I would use that when troubleshooting. The logs in HE are somewhat limited and also get recycled periodically. In order to maintain a history and be able to go back to check, I use Node-red (https://nodered.org) to capture data from HE and log it in a database. The "virtual" switch (naming convention of "Virtual"+Automation name) allows me to log it as an "automation". (Eg: Virtual switch = On, Automation started, Virtual switch=Off, Automation ended)
