Nope all good - the folks at iNovelli are active here as well the amazing @bcopeland. Both have drivers you can use.
(I prefer Brian's though... sorry Eric).
Thanks. What is the main difference between the 2 drivers?
I recommended this for a client who needed a z-wave temp and humidity sensor (for basement rental properties) of which there are very few so he will likely not even be using the light and motion part of the sensor.
They will both do what you want I suspect.. but Brians is more streamlined.
Thanks again. I think I will start with the official driver from Inovelli and see how it goes.
Sounds good - I don't think you will have any issue.
On a side note have you seen this?
You can upgrade your z-wave devices firmware without having to go to a third party hub or stick.
