[INFO] Found good Zigbee Power Strip
I found on Amazon a good Zigbee Power Strip:
It has 4 individually controlled power outlets plus 4 USB-A Ports, 2.1A combined, no power monitoring option.
USB Ports also could be turned On/Off, all 4 together but independent from power outlets.
The suitable driver is built-in "Generic Zigbee Multi-Endpoint Switch" but must be manually assigned after pairing is complete. Pairing is pretty much straight forward process.
Wow, even includes Hubitat in the promotional pic.... Nice.
I am always very skeptical to buy something from unknown manufacture/source but this (mentioning Hubitat) was a selling point. So, I decided to try. Got this toy today and yes, I like it.
Hmm, looks like the old Jinvoo.
Can you post the Device pairing info
e.g. Old Jinvoo strip:
Manufacturer: _TZ3000_cfnprab5
Endpoint 01 application: 64
Endpoint 01 endpointId: 01
Endpoint 01 idAsInt: 1
Endpoint 01 inClusters: 0000,0006,0003,0004,0005,E001
Endpoint 01 initialized: true
Endpoint 01 manufacturer: _TZ3000_cfnprab5
Endpoint 01 model: TS011F
Endpoint 01 profileId: 0104
Endpoint 01 stage: 4
Endpoint 02 endpointId: 02
Endpoint 02 idAsInt: 2
Endpoint 02 inClusters: 0000,0006,0003,0004,0005,E001
Endpoint 02 initialized: true
Endpoint 02 profileId: 0104
Endpoint 02 stage: 4
Endpoint 03 endpointId: 03
Endpoint 03 idAsInt: 3
Endpoint 04 endpointId: 04
Endpoint 04 idAsInt: 4
Endpoint 05 endpointId: 05
Endpoint 05 idAsInt: 5
@kkossev found some issues with different strip versions working well only with specific HE hub versions. :thinking:
Personally I tried a ZigBee strip with a C5 and ended up returning it. :person_shrugging:
Would be really nice to find something that plays better with the Hubitat C5. :crossed_fingers:
Moved to main Lounge section so this doesn't close automatically like Debate Chamber section does.
I thought it looked like the Wi-Fi one's I have bought before (didn't use the smarts, just thought I'd get a smart one in case, knowing it was Smart Life).
Yes, it could be the same device but could be different firmware:
  • manufacturer: _TZ3000_cfnprab5
  • model: TS011F
What I can tell you, it paired very smoothly with C8 Pro and so far control works very well.
I don't have a C5 around to test it with C5.
Based on the reviews, several Hubitat users have them. It'll be interesting to see how this goes. I have a couple places where smart powerstrips would be great, but the Zooz Zen20s (non 800's) were IMO a bit flaky, and the 800's are quite pricy.
An alternative would be nice!
S
I have 2 ZEN20, V2 and they are working just fine. But it looks like Zooz is not making them anymore (any versions).
I just bought one, thesmartesthouse.
Oh, yes. Checked Zooz store and there is 800LR now available. But as @scottgu3 mentioned above they are pricy.
Any regulated safety testing like UL or ETL?
Surprisingly yes, it is ETL certified:
Yeah, I have 2 still, and they work, but if I have to move them to a new hub, it makes me nervous. Since 2019, I've had 4 or 5 of them, and only 2 remain in use, and I think I have a spare. But 2 failed utterly.
With that said, I love Zooz devices on the whole, but the Zen20 is & has been relatively expensive, and in my experience a bit...flaky. :slight_smile:
If they were nearer $50 than $90, perhaps I'd be more forgiving! Lol
S.
This topic was automatically closed 24 hours after the last reply. New replies are no longer allowed.
