As @erktrek notes - get that driver and install it.
Then temporarily change your Zooz double plug device to that driver. Then you can access those controls to view/set your parameters. Then switch back to the regular Zooz double plug driver. Sorry - dupe of above.
Same...the entry on the Device page below, correct? If so, don't worry about that for now - it seems that the displayed parameter values there don't get updated properly/quickly. I updated mine, verified in the logs early this morning. But mine still says 4 on the Device page. Hopefully when the work week starts @bobbyD can confirm.
The Zen15 also has issues with being paired securely. It doesn't take down the mesh (that I can tell) but it doesn't report power. Power reporting is fine if paired unsecurely though.
On my C4 don't see an issue. All power reports are off. The plug was fine on ST, so I'm guessing something with the new 700 series firmware and the plug
I'm not blaming anyone, except maybe silabs. The 700 series seems to have lots of "quirks". This is one of the times I am glad I still have a C5 in addition to the C7, and that Hubitat didn't "upgrade" that C5 Zwave firmware.
Is this strictly a C-7 issue or does it impact the older HEs also? On my C-5, I've stayed on 2.2.2.129 and I have 2 of the ZEN25s. I had been holding off on upgrading FW to 2.2.3 because of all the other issues, but wondering if I should defer until this is corrected.
