The ZEN15 model doesn't support S2 so it shouldn't be joined using any S2 security options.
The devices aren't 700 series yet, these are S2 devices running on the 500 chip (S2 is a software implementation while the chip series is new hardware) but we haven't seen any of these issues on SmartThings which also supports S2 (not many other systems do but ST is definitely the most popular so easy to compare).
@Terk can you check if your plug reports 1.0 or 2.0 (parameter 18 was only added in 2.0)?
@danabw thanks for the tag and vote of confidence
There are some models that underwent hardware changes and if the wrong file is applied to the wrong hardware version it may brick a device. There are a few other reasons behind not publishing the files yet but we'll try our best to add the to the HE firmware library soon!
