IKEA Tretakt Smart Plug (E2204 a.k.a E2240) - PAIRING
Since I've found no right place for pairing info documentation for community devices and I had a hard time pairing the Tretakt , I'd like to document it.
This is for the UK/IRL models sold with firmware 2.4.4
0, install the community driver from here kudos to dandanache
1, plug your treakt to a socket close to the hub (max 0.5m if possible)
2, long press pairing button on the socket till led starts blinking very slowly
3, start zigbee detection in the hub's devices menu (standard detection)
4, when the device is detected, give a name to it, do not configure anything, save it and go to the device.
5, click "update firmware"
6, manually turn on the device (with the button) and wait
7, wait
8, wait
9, wait
after around 15-25 minutes (yes, minutes), the device turns off Then your firmware is updated and now you can use the device.
with firmware 2.4.4 the device is unreliable.
this is the desired state as of 03/15/2025:
in some cases you need to remove the device from hubitat, reset, and re-add (technically redo steps from 1-9
I also suggest to do one device at a time even if you want to onboard more.
Does the IKEA Tretakt show current state properly? I have a bunch of the old IKEA Smart plugs and none of them report their state back to my hub, which makes it impossible to use buttons to toggle on/off..
it is for me.
