You could try the URL
http://YOUR IP ADDRESS HERE/hub/zigbee/getChildAndRouteInfo
If you don't have an xbee to see the mesh, that is the only alternative.
HOWEVER, I will say that my Xiaomi devices (that are reporting every hour as expected and working perfectly) often do not show up on the getChildAndRouteInfo report at all... So don't panick if you don't see all of your devices in that report - it is not super accurate.
If they don't show up then you still don't know how they are being routed.
Thanks for the tips! I ran it and this is what I got:
Parent child parameters
EzspGetParentChildParametersResponse [childCount=4, parentEui64=0000000000000000, parentNodeId=65535]
Child Data
child:[Xiaomi Motion 2, 6F63, type:EMBER_SLEEPY_END_DEVICE]
child:[Xiaomi Mi Cube Controller, D814, type:EMBER_SLEEPY_END_DEVICE]
child:[Xiaomi Motion 1, 46E7, type:EMBER_SLEEPY_END_DEVICE]
child:[Upstairs Bath HT Sensor, 644C, type:EMBER_SLEEPY_END_DEVICE]
Neighbor Table Entry
[Upstairs Hallway Zigbee Smart Plug, 716D], LQI:255, age:3, inCost:1, outCost:5
[null, 8E84], LQI:255, age:7, inCost:1, outCost:0
Route Table Entry
status:Unused
status:Active, age:64, routeRecordState:0, concentratorType:None, [Upstairs Hallway Zigbee Smart Plug, 716D] via [Upstairs Hallway Zigbee Smart Plug, 716D]
status:Unused
status:Unused
status:Unused
status:Unused
status:Unused
status:Unused
status:Unused
status:Unused
status:Unused
status:Unused
status:Unused
status:Unused
status:Unused
status:Unused
From purely guessing it seems all my sensors are talking directly to the hub only. How do I force them to change route? If I don't do anything would they eventually re-route themselves?
Shut down the hub for 20 minutes. Devices will route to the strongest parent, which can be the hub in some cases. However, do not do that at 2am. That is the database backup time.
https://docs.hubitat.com/index.php?title=How_to_Build_a_Solid_Zigbee_Mesh
Or just schedule the zigbee radio to be turned off for 20 minutes as described in this post.
Neat!
Will this work with Xiaomi devices? I never did a mesh healing because I thought the sensors will disconnect and I will have to re add them one by one, I know they will go back to the same device name but it's a pain anyway.
They are stubborn and probably won't, but it won't hurt to try. Xiaomi drop if they miss their checkin, but 20 minutes shouldn't cause all of them to drop.
I have done with Xiaomi devices - but just once (and recently). It worked. A device that kept falling off has now stayed on for a few days.
Thanks guys for the tips. I followed the other post and made a rule to disable Zigbee on the hub for 20 minutes (using a virtual switch). I am now waiting for the mesh to "do its thing" in the next 24 hours.
Hi, is there any way how I can keep power outlet connected to HE plus has it paired with the button?
So I can control the power outlet with HE and the button ( I know that it is not possible to pair button to HE )
Not possible in my tests. The button only supports touchlink and HE does not. The button will steal the pairing away from HE every time you try.
Best to get an outlet from IKEA without the remote, if you need to use IKEA TRÅDFRI for compatibility with Xiaomi, and then use a compatible button with HE to control it. The new Samsung button is one such choice, or you can also use a Xiaomi Mijia button with the community driver. Those are just two of the lesser expensive options.
If you don’t need Xiaomi compatibility, then there are much better outlets than the TRÅDFRI available.
You are right. I'm migrating from SmartThings and I already have Ikea Power Outlets mainly because of it is a good repeater for Xiaomi Sensors - I have plenty of them. And also I'm from EU and therefore I need EU plug - not that many good outlets out there.
I bought three of these to manage Christmas lights. I paired, configured, and then added them to a simple EXSITING lighting rule, WITH A TOGGLE to work off a button on a philips remote, and they stopped the rule working.
I can turn them on and off individually via the Devices page of the hub, and if I use 2 buttons, one for ON and one for OFF.... it works (So problem worked round).
I have a couple of Tradfri bulbs on a separate button, could they be causing a mesh problem?
Anyone else suffered this? Bit of a long shot asking
I’d be looking into the details of your rule not your mesh.
Paste your rule and the community can probably assist.
Agreed. If on/off works from the device details page, you can make an RM rule that does what you need.
Likely something like...
Trigger: Button pressed
Actions:
If light off then
....turn light on
else
....turn light off
end if
OK not sure how to post a rule, so I have taken a screen grab. I have simplified it to try to identify what is going wrong
however, when I press the button, if the outlets are off, then I get:
dev:662020-02-10 06:22:02.807 pm infoSwitching off
dev:982020-02-10 06:22:02.725 pm infoGU10 living room 3 was turned off
dev:332020-02-10 06:22:02.695 pm infoGU10 living room was turned off
dev:32020-02-10 06:22:02.632 pm infoStandard Lamp is off
The outlets are not mentioned in the logs. Unless they are on. Then they are marked as off:
dev:982020-02-10 06:23:33.904 pm infoGU10 living room 3 was turned off
dev:4502020-02-10 06:23:33.868 pm infoOutlet 2 was turned off [digital]
dev:332020-02-10 06:23:33.827 pm infoGU10 living room was turned off
dev:4812020-02-10 06:23:33.812 pm infoOutlet 1 was turned off [digital]
dev:4822020-02-10 06:23:33.755 pm infoOutlet 3 was turned off [digital]
dev:32020-02-10 06:23:33.655 pm infoStandard Lamp is off
At one point I was turning off an outlet, and it was turning off on the dashboard,but not showing in the logs. Struggling to remember what I did to repeat it now. But it was real.
As soon as I put the outlets into the rule (tried several, then something breaks) If I add all 3 outlets to a separate button, then all is well.
Is the [digital] relevant?
Can you explain what the problem is that you're experiencing? Pushing button 2 on "Double wall switch 1" should turn off all the switches/outlets/lights you chose. I don't know all of your devices states before and after, but nothing in the logs looks wrong. This looks like Simple Lighting, and I don't know it's written but wouldn't be surprised if it tried to do some optimizations and only turned off switches that were on, so it may be normal to not see everything in the logs. If these are just device logs, it's also normal not to see anything unless there was actually a state change (e.g., switch becoming off or on from the opposite state).
The "digital" annotation just means that the operation was performed by the hub, as opposed to "phyiscal" which you'd see if you did it on the switch/device yourself (not all devices report this and not all are reliable if/when they do, but it can be useful sometimes).
The rule breaks. Lights no longer go off or come on. Its not the rule. Is definitely something to do with the Outlets from ikea breaking something, so states are read incorrectly or similar.
If I take out the outlets from the rule, then it works reliably. Add in the outlets and they break again.
Reg [digital]... its not on the other items in the list? They are also digital though.
