Hello,
I am trialling several of these devices on my HE Zigbee network and as stated in the subject, the battery life is terrible. I'll get anywhere from a day to a week out of a battery.
Hypotheses
1. Dodgy IKEA batteries
I have burnt through three IKEA batteries within two days, since writing this, I have purchased some Energiser lithium batteries to test if it is a battery issue. However, 30 minutes after inserting an Energiser, its level is now reported as ~50% (down from 100%).
2. Issues with connectivity, not connected to IKEA repeaters
I have read in other posts like this one and this one, which postulate the issue being the devices are not connected to IKEA repeaters (IKEA Tradfri plugs). However, my remotes are all within a meter of a repeater and after viewing th routes at http:///hub/zigbee/getChildAndRouteInfo I can see that all remotes are connected to a IKEA plug.
3. Hardware issue with the remote
I have four remotes all exhibit the same behaviour. None have lasted beyond a couple of weeks, some have only lasted a day. I purchased some of them at different times, but they still might be from the same batch.
This is plausible, but there is not enough evidence either way.
4. Issues with HE
There are several (1) comments (2) by other users that moving away from HE solves the battery issue. This is still only conjecture, however, it does seem like the most likely hypothesis at this point.
[UPDATE] 2021-06-28
I recently purchased a ConBee II and started messing around with Home Assistant. So far the battery life has not changed on the Symfonisk remote at all. In actual fact, the battery has gone up from 47% to 60%. I'm not entirely certain why that would happen, but there you go. I'll add further updates regarding the battery life as I remember to do so.
[UPDATE] 2021-07-04
The battery is still at 60% on Home assistant. I've opened a ticket with Hubitat support, however, it's a bit of a black hole in terms of communication. I don't really know what's going on there, I've asked for feedback or some-kind of acknowledgement but I get nothing. Further attempts to reach out with new tickets are simply shut down. If you're looking for support, don't expect anything brilliant from Hubitat.
[UPDATE] 2021-07-14
While being connected to a Home Assistant box I have built, the battery life remains at 60%. On occasion, when it's particularly cold, the batter seems to drop a bit, however, long term the level remains quite consistent and I am yet to see the same kind of drain I did when it was connected to the HE.
[UPDATE] 2021-07-26
Battery life is still at 60%
[UPDATE] 2021-08-10
Next steps
I'd like to explore the fourth hypothesis a little more, however, I'm not all that experienced with HE yet. I'm looking for guidance on where I might look, or whom I might talk to in order to dig deeper in to the battery life issue. I do have some finite resources at my disposal, so a small amount of coding and debugging of drivers may not be out of the question, but first things first, what's the best way to debunk this hypothesis?
Thanks,
Aaron
Will now stop updating thread!
Anyone w. An idea about how
