This is the driver im using
metadata {
definition(name: "IKEA Window Blinds", namespace: "ryan780", author: "ryan780", ocfDeviceType: "oic.d.blind", mnmn: "SmartThings", vid: "generic-shade") {
capability "Actuator"
capability "Configuration"
capability "Refresh"
capability "Window Shade"
capability "Health Check"
capability "Switch Level"
capability "Battery"
command "pause"
attribute "lastCheckin", "String"
attribute "lastOpened", "String"
fingerprint inClusters: "0000,0001,0003,0004", manufacturer: "IKEA of Sweden", model: "FYRTUR block-out roller blind"
private getCLUSTER_BATTERY_LEVEL() { 0x0001 }
private getCLUSTER_WINDOW_COVERING() { 0x0102 }
private getCOMMAND_OPEN() { 0x00 }
private getCOMMAND_CLOSE() { 0x01 }
private getCOMMAND_PAUSE() { 0x02 }
private getCOMMAND_GOTO_LIFT_PERCENTAGE() { 0x05 }
private getATTRIBUTE_POSITION_LIFT() { 0x0008 }
private getATTRIBUTE_CURRENT_LEVEL() { 0x0000 }
private getCOMMAND_MOVE_LEVEL_ONOFF() { 0x04 }
private List collectAttributes(Map descMap) {
List descMaps = new ArrayList()
descMaps.add(descMap)
if (descMap.additionalAttrs) {
descMaps.addAll(descMap.additionalAttrs)
return descMaps
// Parse incoming device messages to generate events
log.debug "description:- ${description}"
def now = new Date().format("yyyy MMM dd EEE h:mm:ss a", location.timeZone)
// send event for heartbeat
sendEvent(name: "lastCheckin", value: now)
if (description?.startsWith("read attr -")) {
Map descMap = zigbee.parseDescriptionAsMap(description)
if (supportsLiftPercentage() && descMap?.clusterInt == CLUSTER_WINDOW_COVERING && descMap.value) {
log.debug "attr: ${descMap?.attrInt}, value: ${descMap?.value}, descValue: ${Integer.parseInt(descMap.value, 16)}, ${device.getDataValue("model")}"
List descMaps = collectAttributes(descMap)
def liftmap = descMaps.find { it.attrInt == ATTRIBUTE_POSITION_LIFT }
if (liftmap && liftmap.value) {
def newLevel = zigbee.convertHexToInt(liftmap.value)
levelEventHandler(newLevel)
} else if (!supportsLiftPercentage() && descMap?.clusterInt == zigbee.LEVEL_CONTROL_CLUSTER && descMap.value) {
def valueInt = Math.round((zigbee.convertHexToInt(descMap.value)) / 255 * 100)
levelEventHandler(valueInt)
if (descMap?.clusterInt == CLUSTER_BATTERY_LEVEL && descMap.value) {
log.debug "attr: ${descMap?.attrInt}, value: ${descMap?.value}, descValue: ${Integer.parseInt(descMap.value, 16)}"
sendEvent(name: "battery", value: Integer.parseInt(descMap.value, 16))
def levelEventHandler(currentLevel) {
def lastLevel = device.currentValue("level")
log.debug "levelEventHandle - currentLevel: ${currentLevel} lastLevel: ${lastLevel}"
if (lastLevel == "undefined" || currentLevel == lastLevel) { //Ignore invalid reports
log.debug "Ignore invalid reports"
} else {
sendEvent(name: "level", value: currentLevel)
if (currentLevel == 0 || currentLevel == 100) {
sendEvent(name: "windowShade", value: currentLevel == 0 ? "open" : "closed")
} else {
if (lastLevel < currentLevel) {
sendEvent([name:"windowShade", value: "closing"])
} else if (lastLevel > currentLevel) {
sendEvent([name:"windowShade", value: "opening"])
runIn(1, "updateFinalState", [overwrite:true])
def updateFinalState() {
def level = device.currentValue("level")
log.debug "updateFinalState: ${level}"
if (level > 0 && level < 100) {
sendEvent(name: "windowShade", value: "partially open")
def supportsLiftPercentage() {
device.getDataValue("manufacturer") != "Feibit Co.Ltd"
def close() {
log.info "close()"
zigbee.command(CLUSTER_WINDOW_COVERING, COMMAND_CLOSE)
def open() {
log.info "open()"
zigbee.command(CLUSTER_WINDOW_COVERING, COMMAND_OPEN)
def setLevel(data, rate = null) {
log.info "setLevel()"
def cmd
data = data.toInteger()
if (supportsLiftPercentage()) {
cmd = zigbee.command(CLUSTER_WINDOW_COVERING, COMMAND_GOTO_LIFT_PERCENTAGE, zigbee.convertToHexString(data, 2))
} else {
cmd = zigbee.command(zigbee.LEVEL_CONTROL_CLUSTER, COMMAND_MOVE_LEVEL_ONOFF, zigbee.convertToHexString(Math.round(data * 255 / 100), 2))
return cmd
def pause() {
log.info "pause()"
zigbee.command(CLUSTER_WINDOW_COVERING, COMMAND_PAUSE)
- PING is used by Device-Watch in attempt to reach the Device
def ping() {
return zigbee.readAttribute(CLUSTER_BATTERY_LEVEL, 0x0021) // Read the Battery Level
def refresh() {
log.info "refresh()"
def cmds
cmds = zigbee.readAttribute(CLUSTER_WINDOW_COVERING, ATTRIBUTE_POSITION_LIFT)
} else {
cmds = zigbee.readAttribute(zigbee.LEVEL_CONTROL_CLUSTER, ATTRIBUTE_CURRENT_LEVEL)
return cmds
def configure() {
// Device-Watch allows 2 check-in misses from device + ping (plus 2 min lag time)
log.info "configure()"
sendEvent(name: "checkInterval", value: 2 * 60 * 60 + 2 * 60, displayed: false, data: [protocol: "zigbee", hubHardwareId: device.hub.hardwareID])
log.debug "Configuring Reporting and Bindings."
def cmds
cmds = zigbee.configureReporting(CLUSTER_WINDOW_COVERING, ATTRIBUTE_POSITION_LIFT, DataType.UINT8, 0, 600, null)
} else {
cmds = zigbee.levelConfig()
return refresh() + cmds
def setPosition(value){
setLevel(value)
